Home » Newcomers » Newcomers » Eclipse juno is not supporting birt 2.2 + xml+jboss 6(Eclipse juno is not supporting birt 2.2 + xml+jboss 6)
Eclipse juno is not supporting birt 2.2 + xml+jboss 6 [message #1071083] Fri, 19 July 2013 06:03
hi all,
I am developing a module on eclipse europa + apache tomcat server 5.5+birt 2.2.And i am using xml files for writing insert and update queries.Now,i have to transfer the same module in eclipse juno+jboss 6.0+birt 2.2+xml 1.1.All operations are working fine,But my birt report is not opening with this combination.And if i delete jaxb1-impl.jar,jaxb-api-2.0.jar,jaxb-impl-2.0.jar files from my lib folder then birt reports are working fine but no other insertion and updation opertaion is working due to deletion of jaxb's.jar.
From last 10 days i am working on this but I couldnt find any solution.
[org.jboss.resource.connectionmanager.CachedConnectionManager] Closing a connection for you. Please close them yourself: org.jboss.resource.adapter.jdbc.jdk6.WrappedConnectionJDK6@15f563b: java.lang.Throwable: STACKTRACE
at org.jboss.resource.connectionmanager.CachedConnectionManager.registerConnection(CachedConnectionManager.java:278) [:6.1.0.Final]
at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnectionManager2.java:524) [:6.1.0.Final]
at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.allocateConnection(BaseConnectionManager2.java:941) [:6.1.0.Final]
at org.jboss.resource.adapter.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:89) [:6.1.0.Final]
at accounts.cash.global.masters.sequence.CashClassificationSequence.getNextId(CashClassificationSequence.java:51)
at accounts.cash.masters.delegates.Cas_Mst_Classification_Delegates.createCashClass(Cas_Mst_Classification_Delegates.java:205)
at accounts.cash.masters.data.Cas_Mst_Classification_Data.saveDetails(Cas_Mst_Classification_Data.java:133)
at accounts.cash.masters.action.Cas_Mst_Classification_Action.Save(Cas_Mst_Classification_Action.java:156)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) [:1.6.0_01]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) [:1.6.0_01]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) [:1.6.0_01]
at java.lang.reflect.Method.invoke(Unknown Source) [:1.6.0_01]
at org.apache.struts.actions.DispatchAction.dispatchMethod(DispatchAction.java:280)
at org.apache.struts.actions.DispatchAction.execute(DispatchAction.java:216)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:754) [:1.0.0.Final]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:847) [:1.0.0.Final]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:324) [:6.1.0.Final]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:242) [:6.1.0.Final]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:275) [:6.1.0.Final]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:161) [:6.1.0.Final]
at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:181) [:6.1.0.Final]
at org.jboss.modcluster.catalina.CatalinaContext$RequestListenerValve.event(CatalinaContext.java:285) [:1.1.0.Final]
at org.jboss.modcluster.catalina.CatalinaContext$RequestListenerValve.invoke(CatalinaContext.java:261) [:1.1.0.Final]
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:88) [:6.1.0.Final]
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:100) [:6.1.0.Final]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:159) [:6.1.0.Final]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) [:6.1.0.Final]
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158) [:6.1.0.Final]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) [:6.1.0.Final]
at org.jboss.web.tomcat.service.request.ActiveRequestResponseCacheValve.invoke(ActiveRequestResponseCacheValve.java:53) [:6.1.0.Final]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:362) [:6.1.0.Final]
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:877) [:6.1.0.Final]
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:654) [:6.1.0.Final]
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:951) [:6.1.0.Final]
at java.lang.Thread.run(Unknown Source) [:1.6.0_01]
Previous Topic:*Solved* EGit Initial GitHub Import Only Shows Most Recent Commit in Log.
Next Topic:Override Eclipse Command
Current Time: Wed Jul 30 16:40:08 EDT 2025
Powered by FUDForum. Page generated in 0.08797 seconds
