Home » Archived » Jubula » Can I store Jubula test projects in a flat file?
Can I store Jubula test projects in a flat file? [message #1070832] Thu, 18 July 2013 15:29 Go to next message
From my understanding, Jubula test projects are stored in a database. Is it possible to store the test projects in flat files so that we can just push the files onto Jenkins instead of the database, which we haven't even figured out how to do.
Re: Can I store Jubula test projects in a flat file? [message #1072616 is a reply to message #1070832] Tue, 23 July 2013 02:41 Go to previous message
You can export projects as xml files, but they need to be in a database to be executed. Did you have a look at the links I recommended in the other thread?
If you need specific assistance with any aspect of this, which is specifically tailored to your situation, then I'd recommend looking at the options for support.
Hope that helps!
Alex
Previous Topic:How to perform version control and test merge with Jubula?
Next Topic:Problem with Hudson
Current Time: Fri Jul 18 10:52:01 EDT 2025
Powered by FUDForum. Page generated in 0.10291 seconds
