Home » Archived » Jubula » Jubula doesn´t recognize running AUT after upgrade to 2.0
Jubula doesn´t recognize running AUT after upgrade to 2.0 [message #1064220] Tue, 18 June 2013 06:27 Go to next message
Hi there,
upgraded Jubula from 1.2 to 2.0 (latest), switched jar-file and run a clean. AUT is a RCP-Application, wich is installed via Java Web Start (Jubula executes a Batch-file).
After the upgrade Jubula starts the AUT -but when workbench is loaded Jubula does not recognize it and the progress "starting aut" continuous.
Thanks for any tips / hints
Re: Jubula doesn´t recognize running AUT after upgrade to 2.0 [message #1064315 is a reply to message #1064220] Tue, 18 June 2013 11:47 Go to previous messageGo to next message
I don't know if you've reinstalled your AUT along with the Jubula upgrade, but with an RCP app, the first thing I always check is to make sure Jubula's RCP support plugin is properly installed in the AUT. Smile Jubula 2.0 may have a new version of the plugin that needs to be installed.
Re: Jubula doesn´t recognize running AUT after upgrade to 2.0 [message #1064316 is a reply to message #1064220] Tue, 18 June 2013 11:50 Go to previous messageGo to next message
Solved.
JNLP "overwrites" config.ini --> declare property in JNLP:
<resources>
    <property name="osgi.bundles" value="org.eclipse.jubula.rc.rcp@start" />
</resources>
Reference: http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fjava_web_start.htm
Re: Jubula doesn´t recognize running AUT after upgrade to 2.0 [message #1064406 is a reply to message #1064316] Wed, 19 June 2013 02:31 Go to previous messageGo to next message
Great info. We'll add that to the FAQs.
Achim
Re: Jubula doesn´t recognize running AUT after upgrade to 2.0 [message #1070342 is a reply to message #1064316] Wed, 17 July 2013 15:35 Go to previous message
Fabian Ruckwied wrote on Tue, 18 June 2013 17:50
Solved.
@Fabian Ruckwied
This is so helpful!
I had the same problem when I tried to use a project that was working with 1.3 and no longer with 2.0 (I have seen there is a new version 2.1 but I have not tried it yet).
Of course I replaced the old org.eclipse.jubula.rc.rcp_1.3.0.201210161256.jar plugin with the new one org.eclipse.jubula.rc.rcp_2.0.0.201303141505.jar in my RCP app.
I solved my problem by adding org.eclipse.jubula.rc.rcp @ start to the osgi.bundles line in my configuration/config.ini file:
#Product Runtime Configuration File
osgi.configuration.area=C:/programdata/<xxxxxx>/configuration
osgi.instance.area=C:/programdata/<xxxxxx>/workspace
osgi.splashPath=platform:/base/plugins/<xxxxxx>.client.ui
eclipse.application=<xxxxxx>.ui.application
eclipse.product=<xxxxxx>.client.ui.product
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start,org.eclipse.jubula.rc.rcp@start
osgi.bundles.defaultStartLevel=4
#Default connect and read timeouts
sun.net.client.defaultConnectTimeout=5000
sun.net.client.defaultReadTimeout=15000
Thank you a lot for your input.
Previous Topic:extend jubula
Next Topic:How to properly integrate Jubula with Jenkins
Current Time: Fri Jul 25 23:38:48 EDT 2025
Powered by FUDForum. Page generated in 0.25707 seconds
