Home » Eclipse Projects » Standard Widget Toolkit (SWT) » my browser widget is always causing the web kit so's to load
my browser widget is always causing the web kit so's to load [message #1067800] Wed, 10 July 2013 11:55 Go to next message
Hello, for some strange reason my SWT browser always loads the webkit shared object libraries on my RH 6 machines if they are installed.
I did the following test:
On a Redhat 6.3 machine with the following installed:
1. webkitgtk-1.2.6
2. xulrunner 10.0.5
My SWT 3.8 application had a:
-Dorg.eclipse.browser.DefaultType=mozilla
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib64/xulrunner-2/
in its .ini file and the browser that I create code had SWT.MOZILLA passed in to its constructor list. With this configuration, everything comes up and I can launch the about:config page to prove that I am indeed running xulruuner. However, when I close the application it then crashes. While I was investigating that crash, I noticed that when I pmap'ed the process, I saw a:
/usr/lib64/libwebkit-1.0.so.2.17.8
in its shared library list. Further, when I uninstalled webkitgtk, my crash went away.
I have done a grep through my code and there is no where in that code where I ever instantiate a browser that is not SWT.MOZILLA.
Can anyone tell me what other things might cause the webkit libraries to load and if there is anyway to stop it?
Thanks.
-- Mark
Re: my browser widget is always causing the web kit so's to load [message #1069786 is a reply to message #1067800] Tue, 16 July 2013 10:55 Go to previous messageGo to next message
Hi Mark, there should only be a couple of possibilities here, unless
you're seeing an SWT bug:
1. You say that you're setting
-Dorg.eclipse.browser.DefaultType=mozilla, but your property name is
missing its "swt" segment (should be "-Dorg.eclipse.swt.br..."). Was
this just a typo in your question or do you actually have the wrong
property name in your eclipse.ini?
2. If there's another loaded plug-in that creates a Browser with style
SWT.WEBKIT then it will load webkit. Eclipse platform only creates
SWT.NONE-style Browsers, so do you have any other plug-ins that could be
doing this?
Grant
> 1. webkitgtk-1.2.6
> 2. xulrunner 10.0.5
> crash went away.
> Thanks.
> -- Mark
Re: my browser widget is always causing the web kit so's to load [message #1070182 is a reply to message #1069786] Wed, 17 July 2013 08:08 Go to previous message
Hi Grant,
Thanks for replying. The missing swt in the DefaultType specification was a typo when I was writing up this topic for the forum rather than in my actual code.
As for another plugin forcing a SWT.WEBKIT, it is possible but I don't think so. I did a very simple test where I created an application which only had the plugins that get included when you click the include required plugins plus one simple plugin that I created. The one plugin had a single view with a browser widget in it. The browser widget had a SWT.NONE in its constructor and I specified the -Dorg.eclipse.swt.browser.DefaultType=mozilla -Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib64/xulrunner-2/
flags. When I did a pmap on the launched java process, I still saw /usr/lib64/libwebkit-1.0.so.2.17.8 having been loaded in. I also saw the same thing when I ran it passing SWT.MOZILLA to the browser.
It should be noted though that I did not get a crash when I closed my test application.
-- Mark
Previous Topic:SWT Table Viewer
Next Topic:IME
Current Time: Mon Jul 21 10:46:57 EDT 2025
Powered by FUDForum. Page generated in 0.03841 seconds
