Home » Modeling » EMF » [CDO] Databinding - ObservableListTreeContentProvider problem with removes from a list in a CDOView
[CDO] Databinding - ObservableListTreeContentProvider problem with removes from a list in a CDOView [message #1070098] Wed, 17 July 2013 04:30 Go to next message
we are using a JFace-Treeviewer with the ContentProvider 'ObservableListTreeContentProvider' on an CDOObject-List from a CDOView. It works everything very nice Smile
The list here has references and is not containing the elements.
But if we remove an item from the list within a CDOTransaction nothing happens (Additions are working). I have debugged a little, the events are reaching the ContentProvider-Listener for the changes. The Diff-Element from the changeevent looks like this:
org.eclipse.core.databinding.observable.Diffs$8{position [3], isAddition [false], element [UNKNOWN]}
F.e., an addition Diff-Element looks like this:
org.eclipse.core.databinding.observable.Diffs$8{position [3], isAddition [true], element [MyClass@OID459]}
Further on in the listener, the implementation tries to remove the element
element [UNKNOWN]
The SWT-Tree removes nothing, because the element doesn't exist.
I see that the offset is mentioned in the Diff-Element. Is this problem a JFace-Databinding bug or is it CDO related?
Per Sterner
Re: [CDO] Databinding - ObservableListTreeContentProvider problem with removes from a list in a CDOV [message #1071130 is a reply to message #1070098] Fri, 19 July 2013 08:07 Go to previous messageGo to next message
On 17-07-13 10:30, Per Sterner wrote:
> Hello,
> It works everything very nice :)
uh.... an ObservableListTreeContentProvider for a list? That's
potentially odd, unless some top-level node on he list is what you want
to display in a two-level hierarchy. If the children are
non-containement you might need to tweak the getParent() method in the
TreeStructureAdvisor, to return the 'virtual' parent. otherwise
eContainer will be used, but that's not the real parent you see.
> element element [UNKNOWN] The SWT-Tree removes nothing, because the
> Regards,
> Per Sterner
Re: [CDO] Databinding - ObservableListTreeContentProvider problem with removes from a list in a CDOV [message #1072613 is a reply to message #1070098] Tue, 23 July 2013 02:32 Go to previous message
Am 17.07.2013 10:30, schrieb Per Sterner:
> Hello,
> a CDOView. It works everything very nice :)
> changeevent looks like this: org.eclipse.core.databinding.observable.Diffs$8{position [3], isAddition [false], element
> [UNKNOWN]}
> Further on in the listener, the implementation tries to remove the element element [UNKNOWN] The SWT-Tree removes
What CDO version are you using? Newer CDO versions are more relaxed with respect to removed object handling, i.e. they
have these defaults:
public interface CDOStaleReferencePolicy
public static final CDOStaleReferencePolicy DEFAULT = PROXY;
public interface CDOInvalidationPolicy
public static final CDOInvalidationPolicy DEFAULT = RELAXED;
You haven't changed that somehow?
Can you provide me with a runnable piece of code to reproduce your issue? The easiest way is to extend our
AbstractCDOTest. Please have a look at the 2000+ test case implementations.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:Copy On Write EList
Next Topic:Marshalling (XML) / Unresolved Proxy
Current Time: Wed Jul 30 09:50:36 EDT 2025
Powered by FUDForum. Page generated in 0.04336 seconds
