Home » Eclipse Projects » OSEE » Eclipse Installation
Eclipse Installation [message #10668] Wed, 21 January 2009 22:01 Go to next message
I would like to use Eclipse on a couple of different computers.
Once I have configured the installation on one machine, can I just copy
that installation (the Eclipse folders) to another machine and use it?
Is ther an easy way to copy a configuration from one machine to another?
Ray
Re: Eclipse Installation [message #10700 is a reply to message #10668] Thu, 22 January 2009 13:27 Go to previous message
If you are wanting to use copies of the OSEE client to talk to the same
database, then yes, it should be as simple as copying the eclipse
installations to another machine. Zip/Unzip would probably work best.
If you want each instance to use it's own database, you would also need
to export the data from one database and import into the new database.
In posgres, it's a backup/restore.
> Ray
Re: Eclipse Installation [message #571788 is a reply to message #10668] Thu, 22 January 2009 13:27 Go to previous message
> Ray
Previous Topic:Eclipse Installation
Next Topic:Re: Proposal to submit XViewer to eclipse.technology.nebula
Current Time: Sat Nov 01 15:28:50 EDT 2025
Powered by FUDForum. Page generated in 0.03191 seconds
