Home » Eclipse Projects » EclipseLink » Out of memory with level 2 cache enabled(Out of memory with level 2 cache enabled)
Out of memory with level 2 cache enabled [message #1069815] Tue, 16 July 2013 12:17 Go to next message
we have recently enabled level 2 cache with following setting and during runtime we are seeing JVM out of memory.
<property name="eclipselink.cache.type.default" value="Weak" />
<property name="eclipselink.cache.size.default" value="5000" />
<property name="eclipselink.cache.shared.default" value="false" />
Ideally, we are using weak cache and based on the documentation JPA will give up the cache to garbage collector and JVM should not run out of memory. Is my understanding right?
Re: Out of memory with level 2 cache enabled [message #1069955 is a reply to message #1069815] Tue, 16 July 2013 20:37 Go to previous message
correction , settings in persistence.xml is
Previous Topic:Nested Embeddable bug?
Next Topic:Changing from EL 2.1.3 to 2.5.0
Current Time: Fri Jul 18 21:03:01 EDT 2025
Powered by FUDForum. Page generated in 0.24922 seconds
