Home » Modeling » GMF (Graphical Modeling Framework) » Navigating model in gmfmap definition
Navigating model in gmfmap definition [message #106995] Mon, 26 February 2007 12:30 Go to next message
Originally posted by: james.willans.xactium.com
Given an EMF model that consists of A type which can contain many B type
which in turn can contain many C type, is it possible to define a diagram
(without changing the model) which will display instances of A as diagram
nodes, and instances of C as nodes contained in a sub compartment of A?
The problem here are instances of B which have no rendering, so the model
is effectively folded in its rendering. I've played about with "Child
Reference" but these seem to be one step only allowing the immediate child
of the parent being rendered (i.e. this would allow navigation to and then
rendering of B instances but not C instances).
James
Re: Navigating model in gmfmap definition [message #107801 is a reply to message #106995] Wed, 28 February 2007 09:34 Go to previous messageGo to next message
James,
I think maybe https://bugs.eclipse.org/bugs/show_bug.cgi?id=146535
reports the same issue.
Linda
> diagram (without changing the model) which will display instances of A
> as diagram nodes, and instances of C as nodes contained in a sub
> compartment of A? The problem here are instances of B which have no
> rendering, so the model is effectively folded in its rendering. I've
> played about with "Child Reference" but these seem to be one step only
> allowing the immediate child of the parent being rendered (i.e. this
> would allow navigation to and then rendering of B instances but not C
> instances).
> James
Re: Navigating model in gmfmap definition [message #107906 is a reply to message #107801] Wed, 28 February 2007 15:50 Go to previous message
Thanks Linda - that bug is very useful.
James
Previous Topic:how to open another editor by double clicking on an image
Next Topic:transform => generate => launch! Just do it!
Current Time: Tue Oct 14 10:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.02776 seconds
