Home » Archived » Jubula » swing extend example jubula
swing extend example jubula [message #1067725] Wed, 10 July 2013 05:58 Go to next message
Has anyone test the swing extension example succesfully with the last version of jubula (jubula_7.1.00054)?
I follow the extend manual but I have always the same error (5009:AUT Start Failed) when I deploy the feature (with the toolkit plug-in and the rc fragment) and I can't see any errors in the logs.
I only have this line on the client.log:
2013-07-10 11:57:01.975 [Connection.ReaderThread:Socket[addr=localhost/127.0.0.1,port=60000,localport=20402]] ERROR o.e.j.c.c.c.StartAUTServerStateCommand - AUTServer could not start: Error while starting AUT!
I build the feature with the eclipse rcp kepler version.
[Updated on: Wed, 10 July 2013 06:32] by Moderator
Re: swing extend example jubula [message #1069595 is a reply to message #1067725] Tue, 16 July 2013 04:00 Go to previous messageGo to next message
I've got the same problem.
Any ideas, how to fix this?
Re: swing extend example jubula [message #1070237 is a reply to message #1069595] Wed, 17 July 2013 10:20 Go to previous messageGo to next message
The jubula-dev and jubula-rc-dev mailing list archives have some threads within them that have dealt with extensions. It might be worth having a look there. If those threads don't help, it would be great if you could repost the question to the jubula-rc-dev mailing list.
Thanks!
Alex
Re: swing extend example jubula [message #1075369 is a reply to message #1070237] Mon, 29 July 2013 06:06 Go to previous messageGo to next message
I'm having the same issue. In my case I need to select a cell from a JTable that has no column name (header). I guess I need to extend the JTable implementation so I can select a cell by a x/y pair.
Re: swing extend example jubula [message #1077176 is a reply to message #1075369] Thu, 01 August 2013 06:32 Go to previous messageGo to next message
Hi Paraita,
It might also be a good idea to look through the dev and rc-dev lists to see if your question got answered already. Otherwise, send an email to the rc-dev mailing list with your extension example and any log files - someone will have a look at it.
Alex
Re: swing extend example jubula [message #1077183 is a reply to message #1077176] Thu, 01 August 2013 06:39 Go to previous message
Ah, I just saw that this question was kindly answered in another thread.
Previous Topic:How to select the header of a tree table
Next Topic:[solved]JSlider AUT won't run
Current Time: Sun Jul 27 04:16:18 EDT 2025
Powered by FUDForum. Page generated in 0.03247 seconds
