TPTP contributes invalid menu extension with 3.3 [message #106948] |
Tue, 31 July 2007 15:56  |
I just upgraded to Eclipse 3.3 and the new TPTP from Europa. Now every time
I use the context menu in the Package Explorer I get a series of errors
indicating TPTP is contributing an invalid menu extension:
From the log:
!ENTRY org.eclipse.ui 4 4 2007-07-31 14:23:39.201
!MESSAGE Plug-in 'org.eclipse.tptp.monitoring.instrumentation.ui'
contributed an invalid Menu Extension (Path:
'org.eclipse.jdt.ui.source.menu' is invalid):
org.eclipse.tptp.monitoring.instrumentation.ui.CbeExceptionA ddAction1
org.eclipse.tptp.monitoring.instrumentation.ui.CbeEntryExitD eleteAction
org.eclipse.tptp.monitoring.instrumentation.ui.CbeExceptionA ddAction2
org.eclipse.tptp.monitoring.instrumentation.ui.CbeEntryExitA ddAction
!MESSAGE Plug-in 'org.eclipse.tptp.trace.arm.ui' contributed an invalid Menu
Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid):
org.eclipse.tptp.trace.arm.ui.ArmRemovection
org.eclipse.tptp.trace.arm.ui.ArmAddAction
Sure hope there's an easy way to fix this.
-Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107077 is a reply to message #106990] |
Wed, 01 August 2007 13:02   |
Paul,
I installed a clean Eclipse 3.3 yesterday, and got TPTP via the Europa
update site. The TPTP plug-ins include 4.4.0, 4.1.200, 4.2.0, and 4.4.90.
The problem is in Monitoring Implementation UI, which is in feature TPTP
Monitoring Tools Project (4.4.0).
To disable that requires also disabling TPTP Profiling for Web Applications
(4.4.0) and TPTP Tracing and Profiling Tools Project (4.3.100).
I just did a scan for updates on TPTP Monitoring Tools Project and got no
updates found from 3 different sites.
-Ken
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:f8prc5$oj5$1@build.eclipse.org...
> Hi Kenneth,
> This problem was resolved under defect
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=182734 and release in TPTP
> 4.4.0.1:
> http://www.eclipse.org/tptp/home/downloads/
> This release should be the current Europa release. When did you download
> Europa? Can you confirm you are running TPTP 4.4.0.1?
> Paul
> "Kenneth Evans" <evans@aps.anl.gov> wrote in message
> news:f8o46b$2pp$1@build.eclipse.org...
>> Hi,
>> time I use the context menu in the Package Explorer I get a series of
>> errors indicating TPTP is contributing an invalid menu extension:
>> From the log:
>> Menu Extension (Path: 'org.eclipse.jdt.ui.source.menu' is invalid):
>> Thanks,
>> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107222 is a reply to message #107077] |
Thu, 02 August 2007 06:09   |
Hi Ken,
Looks like you have the most recent updates. Please reopen 182734 with
your comments.
Paul
news:f8qebk$svk$1@build.eclipse.org...
> Paul,
> Applications (4.4.0) and TPTP Tracing and Profiling Tools Project
> (4.3.100).
> -Ken
>> Hi Kenneth,
>> 4.4.0.1:
>> Paul
>>> Hi,
>>> From the log:
>>> Thanks,
>>> -Ken
Re: TPTP contributes invalid menu extension with 3.3 [message #107587 is a reply to message #107222] |
Mon, 06 August 2007 02:27   |
I installed Eclipse 3.3 SDK and then TPTP from Europa Discovery site using
"Search for new features to install". Then I did a "Search for updates of
the currently installed features" and found TPTP 4.4.0.1. I took the
default mirror that was selected for me. After installing the TPTP 4.4.0.1
update, the "invalid menu extension" error messages did not occur in the log
any more. The version of TPTP Monitoring Tools Project feature after
installing TPTP 4.4.0.1 is 4.4.0.v200706132116-7U7R_7-watmDA97KFbmUlBcq0yXH
and the version of the org.eclipse.tptp.monitoring.instrumentation.ui plugin
is 4.4.0.v200707070100.
Ken, are these the steps you followed and are these the versions you have
installed?
Dave
news:f8sahk$r4u$1@build.eclipse.org...
> Hi Ken,
with
> your comments.
> Paul
> > Paul,
4.4.90.
> > (4.3.100).
no
> > -Ken
> >> Hi Kenneth,
TPTP
> >> 4.4.0.1:
download
> >> Paul
> >>> Hi,
every
> >>> From the log:
invalid
invalid
> >>> Thanks,
> >>> -Ken
FUDForum. Page generated in 0.33621 seconds
