Home » Archived » Eclipse Process Manager (Stardust) » Customize the workflow execution left panel(How can I customize the left panel in the workflow execution perspective)
Customize the workflow execution left panel [message #1069315] Mon, 15 July 2013 12:46 Go to next message
Is it possible to configure, which launchpads are expanded after the login?
As I can see, eg. the bean WorklistsBean setExpanded(true); in the init method.
Is this the only place to set this property?
Re: Customize the workflow execution left panel [message #1070052 is a reply to message #1069315] Wed, 17 July 2013 02:43 Go to previous message
Florian,
in the portal configuration you can configure which perspective should be show after login, but we don't have the option to configure the expanded state of the individual launch panels there.
It should be possible to modify this bean property by editing the spring ui-context xml file that declares the launch panel. However, that would force you to modify a jar. A preferable option would be a bean post processor that will set the launch panel properties as required. We will try this out and post an example on the wiki if it works.
Best regards
Rob
Previous Topic:NullPointerException in UserUserGroupLink#delete
Next Topic:Stardust with rule engine (Drools)
Current Time: Wed Jul 30 20:16:03 EDT 2025
Powered by FUDForum. Page generated in 0.24412 seconds
