Home » Eclipse Projects » EclipseLink » ERROR - Predicate "OR" is NULL --solved(Dynamic "OR"-query using Predicate -howto?)
ERROR - Predicate "OR" is NULL --solved [message #1069105] Mon, 15 July 2013 03:15 Go to next message
Hello everybody,
For a RCP application I try to build a dynamic query: depending on user input several search criteria should be concatenated.
I used a Predicate, but it returns a NullPointerException.
What I did is:
		CriteriaBuilder builder = em.getCriteriaBuilder();
		CriteriaQuery query = builder.createQuery();
		Root c = query.from(ContactImpl.class);
		Predicate where = builder.conjunction();
		where.alias("MyNameIsAlias");
		System.out.println("## where="+where);
		System.out.println("## alias="+where.getAlias());
		System.out.println("## where=null? "+where.isNull());
		where=builder.or(where, builder.like(c.get("name"), searchString));
		where=builder.or(where, builder.like(c.get("firstName"), searchString));
		where=builder.or(where, builder.like(c.get("lastName"), searchString));
		query.where(where);
However, unfortunately the method fails before getting to the search criteria. The predicate has an id, but when I ask if its null I get the exception:
## where=org.eclipse.persistence.internal.jpa.querydef.PredicateImpl@180b22e
## alias=MyNameIsAlias
Exception in thread "main" java.lang.NullPointerException
	at org.eclipse.persistence.internal.jpa.querydef.ExpressionImpl.isNull(ExpressionImpl.java:147)
I am very confused, first the predicate is there, then it is null !?
(just added the alias to test, I get the same result without it.)
When I did the query like this, all was fine:
//		query.where(builder.or(
//				(builder.like(c.get("name"), searchString)),
//				(builder.like(c.get("firstName"), searchString)),
//				(builder.like(c.get("lastName"), searchString))
What is going wrong here?
How else could I construct a dynamic query like this?
Any hints are wellcome!
Hannes
--using Eclipse Juno Service Release 2 and
EclipseLink version: 2.5.0.v20130507-3faac2b
[Updated on: Thu, 18 July 2013 02:41] by Moderator
Re: ERROR - Predicate is (or is not?) NULL [message #1069263 is a reply to message #1069105] Mon, 15 July 2013 10:46 Go to previous messageGo to next message
A conjunction is true, so what you would be are creating is "where true is null" which doesn't make a lot of sense. You can file a bug to have a better error thrown, but I don't see what you are attempting to do with the println statements - they should be removed.
Best Regards,
Chris
Re: ERROR - Predicate is (or is not?) NULL [message #1069271 is a reply to message #1069263] Mon, 15 July 2013 11:10 Go to previous messageGo to next message
Chris,
I added the println statements to find out where the NullPointer Exception is coming from.
If I omit them and try to build the Predicate like that
I still get the NullPointer Exception.
Do you have any Idea what is going wrong?
Hannes
Re: ERROR - Predicate is (or is not?) NULL [message #1069278 is a reply to message #1069271] Mon, 15 July 2013 11:26 Go to previous messageGo to next message
Chris,
thanks for pointing me in this direction.
conjunction/"and" works,
		where=builder.and(where, builder.like(c.get("name"), searchString));
		where=builder.and(where, builder.like(c.get("firstName"), searchString));
		query.where(where);
but disjunction/"or" does not:
		Predicate where = builder.disjunction();
		query.where(where);
This code still produces the NullPointer Exception.
	at org.eclipse.persistence.internal.jpa.querydef.CriteriaBuilderImpl.or(CriteriaBuilderImpl.java:413)
How do you construct a select-or statement dynamically?
Hannes
[Updated on: Mon, 15 July 2013 12:10] by Moderator
Re: ERROR - Predicate is (or is not?) NULL [message #1069764 is a reply to message #1069278] Tue, 16 July 2013 10:07 Go to previous messageGo to next message
Seems like a bug, please log the bug including your code and the exception stack trace.
As a workaround use,
where=builder.like(c.get("name"), searchString);
query.where(where);
Re: ERROR - Predicate is (or is not?) NULL [message #1069771 is a reply to message #1069764] Tue, 16 July 2013 10:20 Go to previous messageGo to next message
Great, this works!
stupid I did not think of it myself ...
I'll find out how to log a bug.
thanks James!
Hannes
Re: ERROR - Predicate is (or is not?) NULL [message #1069795 is a reply to message #1069771] Tue, 16 July 2013 11:17 Go to previous messageGo to next message
I've logged a bug with a patch at https://bugs.eclipse.org/bugs/show_bug.cgi?id=413084
Re: ERROR - Predicate is (or is not?) NULL [message #1070110 is a reply to message #1069105] Wed, 17 July 2013 05:02 Go to previous message
I'm quite surprised this bug did not show up earlier, it is not an uncommon query.
Thanks Chris!
Hannes
Previous Topic:EclipseLink-6069 when using BatchFetch and Inheritance
Next Topic:Using Fetch-Group with Many-to-One
Current Time: Wed Jul 23 02:00:33 EDT 2025
Powered by FUDForum. Page generated in 0.05128 seconds
