| [ATL] Call an operation [message #106892] |
Fri, 19 June 2009 04:54  |
I'm working on a higher order transformation, with the following scenario:
*** (T1 - HOT): M1 -> ATL ***
- from M1 I get the string of the operations I need to call in the
generated T2 transformation, on the input types of T2.
*** (T2): M2 -> M3 (with the use of an ATL library) ***
- some target elements in M3 need to be constructed by calling on M2
types, operations defined in an ATL library for those types, these
operations being identified, inside a helper, by a String parameter,
belonging to the helper.
Sample:
rule A {
| Re: [ATL] Call an operation by a string [message #106909 is a reply to message #106892] |
Fri, 19 June 2009 05:01   |
Sorry for the incomplete post (new keyboard).
- some target elements in M3 need to be constructed by calling on M2 types
(all of them), operations defined in an ATL library for those types, these
Sample:
--this will lool like the generated code
uses Utils;
rule R {
from
a:M2!TypeM2
to
b:M3!TypeM3 (
value <- thisModule.getValue(operationName)
helper def : getValue(operationName : String) :String =
M2!TypeM2.allInstances()-> collect(it|it.'operationName').iterate(e;res:String=''|res.c oncat(e));
in which the operation is defined on the type M2 in the Utils library.
I really don't know if it's clear, please ask to clarify. Thank you!
Cosmin
| Re: [ATL] Call an operation by a string [message #106936 is a reply to message #106909] |
Fri, 19 June 2009 05:15  |
Kind of reflection if you like and invoke a method on a type, by knowing
its name.
As an alternative of doing this, I could generate rules or just ouput
patterns for all of the strings I need to pass from M1 to T2. This way, in
each rule, I can write the operation corresponding to the string directly.
But this will be a lot of generated code an I was wondering how to pass
the collection of strings and have a general helper, which takes as
parameter one string at a time, to do my job.
Cosmin
FUDForum. Page generated in 0.04398 seconds
