Deployment problem on GlassFish 4 [message #1068764] |
Sun, 14 July 2013 05:25  |
Hi everyone,
I've just tried to deploy Hudson 3.0.1 on GlassFish 4, and the deployment ended up with the following log messages:
[2013-07-14T05:22:17.632+0400] [glassfish 4.0] [INFO] [] [org.glassfish.admingui] [tid: _ThreadID=36 _ThreadName=admin-listener(4)] [timeMillis: 1373764937632] [levelValue: 800] [[
GUI deployment: uploadToTempfile]]
[2013-07-14T05:22:17.681+0400] [glassfish 4.0] [INFO] [] [org.glassfish.admingui] [tid: _ThreadID=36 _ThreadName=admin-listener(4)] [timeMillis: 1373764937681] [levelValue: 800] [[
uploadFileName=hudson-3.0.1.war]]
[2013-07-14T05:22:56.460+0400] [glassfish 4.0] [INFO] [] [javax.enterprise.system.tools.deployment.common] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764976460] [levelValue: 800] [[
visiting unvisited references]]
[2013-07-14T05:23:07.136+0400] [glassfish 4.0] [INFO] [] [org.jboss.weld.Version] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764987136] [levelValue: 800] [[
WELD-000900 2.0.0 (SP1)]]
[2013-07-14T05:23:08.852+0400] [glassfish 4.0] [WARNING] [] [org.glassfish.weld.BeanDeploymentArchiveImpl] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764988852] [levelValue: 900] [[
AS-CDI-005]]
[2013-07-14T05:23:19.286+0400] [glassfish 4.0] [WARNING] [] [org.jboss.weld.interceptor.util.InterceptionTypeRegistry] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999286] [levelValue: 900] [[
Class 'javax.ejb.PostActivate' not found, interception based on it is not enabled]]
[2013-07-14T05:23:19.288+0400] [glassfish 4.0] [WARNING] [] [org.jboss.weld.interceptor.util.InterceptionTypeRegistry] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999288] [levelValue: 900] [[
Class 'javax.ejb.PrePassivate' not found, interception based on it is not enabled]]
[2013-07-14T05:23:19.982+0400] [glassfish 4.0] [SEVERE] [NCLS-CORE-00026] [javax.enterprise.system.core] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999982] [levelValue: 1000] [[
Exception during lifecycle processing
org.glassfish.deployment.common.DeploymentException: CDI deployment failure:Exception List with 2 exceptions:
Exception 0 :
org.jboss.weld.exceptions.DeploymentException: WELD-001408 Unsatisfied dependencies for type [Injector] with qualifiers [@Default] at injection point [[BackedAnnotatedField] @Inject private org.sonatype.guice.bean.binders.TypeConverterMap.injector]
at org.jboss.weld.bootstrap.Validator.validateInjectionPointForDeploymentProblems(Validator.java:403)
at org.jboss.weld.bootstrap.Validator.validateInjectionPoint(Validator.java:325)
at org.jboss.weld.bootstrap.Validator.validateGeneralBean(Validator.java:177)
at org.jboss.weld.bootstrap.Validator.validateRIBean(Validator.java:208)
at org.jboss.weld.bootstrap.Validator.validateBean(Validator.java:519)
at org.jboss.weld.bootstrap.Validator.validateBeans(Validator.java:505)
at org.jboss.weld.bootstrap.Validator.validateDeployment(Validator.java:480)
at org.jboss.weld.bootstrap.WeldBootstrap.validateBeans(WeldBootstrap.java:536)
at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:216)
at org.glassfish.kernel.event.EventsImpl.send(EventsImpl.java:131)
at org.glassfish.internal.data.ApplicationInfo.load(ApplicationInfo.java:328)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:493)
at com.sun.enterprise.v3.server.ApplicationLifecycle.deploy(ApplicationLifecycle.java:219)
at org.glassfish.deployment.admin.DeployCommand.execute(DeployCommand.java:491)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:527)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$2$1.run(CommandRunnerImpl.java:523)
at javax.security.auth.Subject.doAs(Subject.java:356)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$2.execute(CommandRunnerImpl.java:522)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:546)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.doCommand(CommandRunnerImpl.java:1423)
at com.sun.enterprise.v3.admin.CommandRunnerImpl.access$1500(CommandRunnerImpl.java:108)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1762)
at com.sun.enterprise.v3.admin.CommandRunnerImpl$ExecutionContext.execute(CommandRunnerImpl.java:1674)
at org.glassfish.admin.rest.utils.ResourceUtil.runCommand(ResourceUtil.java:235)
at org.glassfish.admin.rest.utils.ResourceUtil.runCommand(ResourceUtil.java:257)
at org.glassfish.admin.rest.resources.TemplateListOfResource.createResource(TemplateListOfResource.java:134)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:125)
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:152)
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:91)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:346)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:341)
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:101)
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:224)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317)
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:198)
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:946)
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:331)
at org.glassfish.admin.rest.adapter.RestAdapter$2.service(RestAdapter.java:318)
at org.glassfish.admin.rest.adapter.RestAdapter.service(RestAdapter.java:181)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:246)
at org.glassfish.grizzly.http.server.HttpHandler.runService(HttpHandler.java:191)
at org.glassfish.grizzly.http.server.HttpHandler.doHandle(HttpHandler.java:168)
at org.glassfish.grizzly.http.server.HttpServerFilter.handleRead(HttpServerFilter.java:189)
at org.glassfish.grizzly.filterchain.ExecutorResolver$9.execute(ExecutorResolver.java:119)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:288)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:206)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:136)
at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:114)
at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77)
at org.glassfish.grizzly.nio.transport.TCPNIOTransport.fireIOEvent(TCPNIOTransport.java:838)
at org.glassfish.grizzly.strategies.AbstractIOStrategy.fireIOEvent(AbstractIOStrategy.java:113)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.run0(WorkerThreadIOStrategy.java:115)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy.access$100(WorkerThreadIOStrategy.java:55)
at org.glassfish.grizzly.strategies.WorkerThreadIOStrategy$WorkerThreadRunnable.run(WorkerThreadIOStrategy.java:135)
at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:564)
at org.glassfish.grizzly.threadpool.AbstractThreadPool$Worker.run(AbstractThreadPool.java:544)
at java.lang.Thread.run(Thread.java:724)
Exception 0 :
org.jboss.weld.exceptions.DeploymentException: WELD-001408 Unsatisfied dependencies for type [Injector] with qualifiers [@Default] at injection point [[BackedAnnotatedParameter] Parameter 1 of [BackedAnnotatedMethod] @Inject org.sonatype.guice.bean.locators.DefaultBeanLocator.autoPublish(Injector)]
at org.glassfish.weld.WeldDeployer.event(WeldDeployer.java:225)
Caused by: org.jboss.weld.exceptions.DeploymentException: Exception List with 2 exceptions:
Exception 0 :
Exception 0 :
at org.jboss.weld.bootstrap.Validator.validateBeans(Validator.java:511)
... 59 more
[2013-07-14T05:23:19.985+0400] [glassfish 4.0] [SEVERE] [] [javax.enterprise.system.core] [tid: _ThreadID=148 _ThreadName=admin-listener(9)] [timeMillis: 1373764999985] [levelValue: 1000] [[
Exception while loading the app]]
As far as I can tell, there's some trouble with injecting of dependencies, i. e. CDI subsystem. I'm not experienced in this matter, so any hints on the source of the problem will be appreciated a lot.
Thanks in advance,
Roman
Re: Deployment problem on GlassFish 4 [message #1069351 is a reply to message #1068764] |
Mon, 15 July 2013 14:12  |
Stuart,
thank you for the detailed information and useful links!
I managed to deploy Hudson using this setting you've mentioned:asadmin set configs.config.server-config.cdi-service.enable-implicit-cdi=false It seems like GlassFish 4 is misconfigured in respect of CDI 1.1 by default.
FUDForum. Page generated in 0.05391 seconds
