Home » Eclipse Projects » EclipseLink » Abstract Entity without children
Abstract Entity without children [message #1068420] Sat, 13 July 2013 04:04 Go to next message
I have a modular system where modules implement abstract jpa entities. If no module - which implements such an abstract class - is available EclipseLink complains:
Internal Exception: Exception [EclipseLink-108] (Eclipse Persistence Services - 2.5.0.v20130507-3faac2b): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: Cannot find value in class indicator mapping in parent descriptor [null].
Descriptor: RelationalDescriptor(my.AbstractEntity --> [DatabaseTable(ABSTRACTENTITY)])
  at org.eclipse.persistence.exceptions.DescriptorException.valueNotFoundInClassIndicatorMapping(DescriptorException.java:1791)
  at org.eclipse.persistence.descriptors.InheritancePolicy.initializeOnlyInstancesExpression(InheritancePolicy.java:1055)
  at org.eclipse.persistence.descriptors.InheritancePolicy.initialize(InheritancePolicy.java:1016)
  at org.eclipse.persistence.descriptors.ClassDescriptor.initialize(ClassDescriptor.java:3051)
I tried calling InheritancePolicy#setShouldReadSubclasses(true) but InheritancePolicy#initialize() resets it to false if there are no children.
What's the simplest way to make this work? I don't want to have dummy implementations and empty dummy tables...
Re: Abstract Entity without children [message #1069752 is a reply to message #1068420] Tue, 16 July 2013 09:41 Go to previous message
How have you mapped the Entity? Are you using @MappedSuperclass? If not, you probably should.
Previous Topic:Many Warnings from JPA-Added RowIDs When Database Change Notification Enabled
Next Topic:private-owned versus orphan-removal versus cascade-remove
Current Time: Sun Jul 27 04:08:10 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
