Home » Archived » BIRT » how to drop according to parameter
how to drop according to parameter [message #1067378] Mon, 08 July 2013 09:14 Go to next message
Hi,i have design query in before open for country and product line and i have filter in table and drop in before Factory for top10,top25,bottom10,bottom25 but am struggling how to drop by quantity and sale according to report and All option in Radio button for country
i have attached a sample report for u r reference
kindly provide sample db for this report
thank in advance
[Updated on: Mon, 08 July 2013 09:16] by Moderator
Re: how to drop according to parameter [message #1067600 is a reply to message #1067378] Tue, 09 July 2013 10:27 Go to previous messageGo to next message
kindly reply for this post...
thank in advance
Re: how to drop according to parameter [message #1068293 is a reply to message #1067600] Fri, 12 July 2013 18:34 Go to previous messageGo to next message
The beforeFactory method happens before any data is available to the report, so you wouldn't be able to drop based on data unless you use the data engine to connect to your data in the beforeFactory and determine what to drop by doing that. If you need your data to determine whether to show the elements or not, you should just use the visibility property.
Re: how to drop according to parameter [message #1068502 is a reply to message #1068293] Sat, 13 July 2013 09:43 Go to previous messageGo to next message
thank u for reply ....i have tried but no result can u provide sample db for above report ...
thank in advance
[Updated on: Sat, 13 July 2013 09:43] by Moderator
Re: how to drop according to parameter [message #1070251 is a reply to message #1068502] Wed, 17 July 2013 10:44 Go to previous messageGo to next message
Re: how to drop according to parameter [message #1071197 is a reply to message #1070251] Fri, 19 July 2013 10:38 Go to previous message
thank for Michael Williams i got solution by ur idea.........
and then kinldy look at this thread
http://www.eclipse.org/forums/index.php/t/491177/
thank u
Previous Topic:tabbed birt chart
Next Topic:how to customizes query for parameter
Current Time: Wed Jul 23 07:39:29 EDT 2025
Powered by FUDForum. Page generated in 0.05607 seconds
