Jubula and IBM JRE [message #1068125] |
Fri, 12 July 2013 05:56  |
I am trying to work with Jubula on a Swing-Client application running under IBM's JRE
"IBM J9 VM (build 2.6, JRE 1.6.0 Windows 7 x86-32 20110729_87983 (JIT enabled, AOT enabled)"
The client starts via Batch-File. If I start the AUT, the Logon Screen appears but the Running AUT's view doesn't show the application.
If I change the JRE to an Oracle JRE, the Logon Screen appears and the Running AUT's view shows the running AUT-ID.
Unfortunately we cannot use an Oracle JRE.
Is there a solution for this problem?
Re: Jubula and IBM JRE [message #1077132 is a reply to message #1069088] |
Thu, 01 August 2013 05:33  |
unfortunately, testing my Swing application running under IBM'S JRE has another problem. Starting the application works, the Login Screen appears, AUT is recognised and Object Mapping Mode works for the Login Screen. But after entering a valid User/Password, the application main screen is not shown. AUT ist still running but trying to switch to Object Mapping Mode will cause an 5009 error and AUT is closed. It seems that the application is running in background but it is not possible to bring it to the foreground. The main screen consists of a JDesktopPane and ist started in a new tread.
- Klaus
FUDForum. Page generated in 0.12226 seconds
