| Error in Chart Parameter Binding in 2.0RC [message #106716] |
Tue, 10 January 2006 05:51  |
Originally posted by: andy.lawton.nospam.com
There is an error when trying to use parameters in charts.
Create a data set with a single parameter.
Create a chart and bind this data set as the source for the chart data by
checking the Use Data Set radio button and selecting the data for the series
you want.
Press the Parameters button, and try to use a report parameter instead of
the default value. If you do this, you get the following:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.0.0
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: Error evaluating Javascript
expression. Script engine error: ReferenceError: "params" is not defined.
Script source: ParamBinding(STAD), line: 0, text:
params["STAD"]. See next exception for more information.
Error evaluating Javascript expression. Script engine error: ReferenceError:
params["STAD"]
This all worked fine in M2. In fact, I can't open reports I created in M2
with 2.0RC.
Andy
FUDForum. Page generated in 0.05633 seconds
