Home » Modeling » EMF » References in EMF
References in EMF [message #1068042] Thu, 11 July 2013 15:17 Go to next message
I'm wondering how references are handled in EMF. I've got the following metamodel witht he according emf code:
index.php/fa/15571/0/
class Platform{
  	unsettable attr EString name = "Platform";
  	attr EString reference = "";
  	attr EString identifier = "";
  	val Variationpoint[*] variationpoints;
class Variationpoint{
	unsettable attr EString name = "Variationpoint";
	attr EString description = "";
Normally I would expect that this reference is bidirectional. So that Platform has an arbitrary number of Variationpoints and a Variationpoint knows its paltform. But this doesn't seems to be the case? I'm not able to acces the according Platform with an Variationpoint object.
Re: References in EMF [message #1068046 is a reply to message #1068042] Thu, 11 July 2013 15:21 Go to previous messageGo to next message
Phil,
Comments below.
On 11/07/2013 9:17 PM, Phil H wrote:
> class Platform{
Is this Emfatic syntax? Is variationpointsa containment reference?
Where? I don't see a reference to Platform from Variationpoint.
I don't see two references only one unidirectional reference.
Re: References in EMF [message #1068139 is a reply to message #1068046] Fri, 12 July 2013 07:52 Go to previous messageGo to next message
Hi Ed,
yes it's emfatic syntax. The keyword val means a "by value" EReference (EReference.containment = true).
I thought a aggregation is handled bidirectional, but indeed it's unidirectional. So to overcome this, I tried to use an additional reference:
index.php/fa/15578/0/
But when I create a Platform and add a Variationpoint to this Platform, the Variationpoint don't know it's platform. The user has to assign the reference in the property view manually.
How can I define a bidirectional aggregation in EMF?:
index.php/fa/15579/0/
Re: References in EMF [message #1068144 is a reply to message #1068139] Fri, 12 July 2013 08:11 Go to previous message
Phil,
I don't know the Emfatic syntax. In the structured editor you set the
opposite feature of one of the references to point at the other in the
properties view.
On 12/07/2013 1:52 PM, Phil H wrote:
> Hi Ed,
Previous Topic:restriction of child elements
Next Topic:Traversing all resources from XMI-file
Current Time: Wed Jul 30 12:11:57 EDT 2025
Powered by FUDForum. Page generated in 0.03212 seconds
