Home » Modeling » EMF » [CDO] cleaning corrupt entries in a CDOResource getContents()
[CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067938] Thu, 11 July 2013 07:06 Go to next message
Our DB is corrupt, likely happened with some of the recent bugs i logged.
Now I am trying to fix the DB.
I am trying to delete entries from a Resource which do not have
corresponding objects. (So are basically marked as Stale).
For this I need the feature for Resource.getContents. I am however not
finding the corresponding feature in ECorePackage.Literals.
so the attempt will be this. Can this work?
CDOResource cdoRes = ...
for (EObject eo : cdoRes.getContents()) {
CDOObject cdoObject = CDOUtil.getCDOObject(eo);
int indexOf = cdoRes.getContents().indexOf(eo);
if (CDOUtil.isStaleObject(eo)) {
System.out.println(cdoObject + " is a stale object");
CDOUtil.cleanStaleReference(cdoRes, [EStructuralFeature], indexOf);
thanks Christophe
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067939 is a reply to message #1067938] Thu, 11 July 2013 07:09 Go to previous messageGo to next message
Am 11.07.2013 13:06, schrieb Christophe Bouhier:
> Our DB is corrupt,
What does that mean exactly?
Cheers
/Eike
http://www.esc-net.de
> I am trying to delete entries from a Resource which do not have corresponding objects. (So are basically marked as
> Stale).
> For this I need the feature for Resource.getContents. I am however not finding the corresponding feature in
> System.out.println(cdoObject + " is a stale object"); CDOUtil.cleanStaleReference(cdoRes,
> thanks Christophe
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067941 is a reply to message #1067939] Thu, 11 July 2013 07:19 Go to previous messageGo to next message
>> Hi,
>> Our DB is corrupt,
this is perhaps a strong word, maybe simply stale references.
what I see is that one of the entries the table eresource_CDOResource
has a count 1000.
the table eresource_CDOResource_contents_list has 1000 entries,
of these 1000, only a fraction actual point to valid CDOObjects in other
tables.
The effect, is an ObjectNotFoundException. Is this a valid case of a
stale reference, or can I use the term 'corrupt'?
I found the feature I was looking for. it's this I believe:
EresourcePackage.Literals.CDO_RESOURCE__CONTENTS
rgds Christophe
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> thanks Christophe
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067952 is a reply to message #1067941] Thu, 11 July 2013 08:11 Go to previous messageGo to next message
Am 11.07.2013 13:19, schrieb Christophe Bouhier:
>>> Hi,
>>> Our DB is corrupt,
> what I see is that one of the entries the table eresource_CDOResource has a count 1000.
> of these 1000, only a fraction actual point to valid CDOObjects in other tables.
> The effect, is an ObjectNotFoundException. Is this a valid case of a stale reference, or can I use the term 'corrupt'?
That can only be considered corrupt if you enabled referential integrity checking (all the time). Otherwise it's normal
stale references.
Cheers
/Eike
> rgds Christophe
>> Cheers
>> /Eike
>>> thanks Christophe
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067955 is a reply to message #1067952] Thu, 11 July 2013 08:22 Go to previous messageGo to next message
>>>> Hi,
>>>> Our DB is corrupt,
>> has a count 1000.
>> other tables.
> checking (all the time). Otherwise it's normal stale references.
Ok, well referential integrity is not on. I do wonder how this can
happen with a contained object. Isn't the reference removed /unset
automatically? Or in other words, how can I do get in such a state
programmaticly? If I do this cdoRes.getContents().remove(i); then I
would assume the reference is also removed right? Sorry, maybe I am
missing out on something here.
> Cheers
> /Eike
>> rgds Christophe
>>> Cheers
>>> /Eike
>>>> thanks Christophe
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067960 is a reply to message #1067938] Thu, 11 July 2013 08:48 Go to previous messageGo to next message
Ok, we already agreed, it's not corruption in that sense ;-)
> Stale).
Looks good to me. We should add a CDOUtil.cleanStaleReferences() method.
Cheers
/Eike
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067962 is a reply to message #1067955] Thu, 11 July 2013 08:52 Go to previous messageGo to next message
Am 11.07.2013 14:22, schrieb Christophe Bouhier:
>>>>> Hi,
>>>>> Our DB is corrupt,
>>> has a count 1000.
>>> other tables.
> Ok, well referential integrity is not on. I do wonder how this can happen with a contained object. Isn't the reference
> removed /unset automatically? Or in other words, how can I do get in such a state programmaticly? If I do this
> cdoRes.getContents().remove(i); then I would assume the reference is also removed right? Sorry, maybe I am missing out
> on something here.
Oops, I missed the point that EresourcePackage.Literals.CDO_RESOURCE__CONTENTS is in fact a containment reference. Are
you sure you're not executing manual SQL queries that delete stuff?
Cheers
/Eike
Re: [CDO] cleaning corrupt entries in a CDOResource getContents() [message #1067964 is a reply to message #1067962] Thu, 11 July 2013 08:56 Go to previous message
>>>>>> Hi,
>>>>>> Our DB is corrupt,
>>>> has a count 1000.
>>>> other tables.
> containment reference. Are you sure you're not executing manual SQL
200% sure. But if you recall this one
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396743
, and some other recent bugs, it could be the reason..
We are still on the an older CDO version, as because of this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412520
> Cheers
> /Eike
Previous Topic:Invalid proxy URI after unloading a resource
Next Topic:Class inheritance across plugins
Current Time: Thu Jul 31 12:54:34 EDT 2025
Powered by FUDForum. Page generated in 0.06144 seconds
