Home » Modeling » OCL » ClassCastException thrown when using ecore::EDouble
ClassCastException thrown when using ecore::EDouble [message #1067896] Thu, 11 July 2013 03:36 Go to next message
Hi Ed,
I have a very simple ecore model (the full project with the genmodel is in attachment too):
import ecore : 'http://www.eclipse.org/emf/2002/Ecore#/';
package components : components = 'http://components/1.0'
	class Container
		attribute requiredWeight : ecore::EDouble;
		attribute actualWeight : ecore::EDouble { derived readonly transient volatile }
			derivation: components.weight
					->sum();
		property components#parentContainer : Component[*] { ordered composes };
		invariant validWeight('The actual weight exceeds the required weight'): if actualWeight > requiredWeight
				then null
				else true
				endif;
	class Component
		property parentContainer#components : Container;
		attribute weight : ecore::EDouble;
When I generate Java code for this example, I see that the generated getActualWeight method of the Container class looks like this:
	public double getActualWeight() {
		 * components.weight->sum()
		final /*@NonNull*/ /*@NonInvalid*/ components.Container self = this;
		final /*@NonNull*/ /*@NonInvalid*/ DomainEvaluator evaluator = new EcoreExecutorManager(this, ComponentsTables.LIBRARY);
		final /*@NonNull*/ /*@NonInvalid*/ IdResolver idResolver = evaluator.getIdResolver();
		final /*@NonNull*/ /*@Thrown*/ List<?> components = self.getComponents();
		final /*@NonNull*/ /*@Thrown*/ OrderedSetValue BOXED_components = idResolver.createOrderedSetOfAll(ComponentsTables.ORD_CLSSid_Component, components);
		/*@NonNull*/ /*@NonInvalid*/ SequenceValue.Accumulator accumulator = ValuesUtil.createSequenceAccumulatorValue(ComponentsTables.SEQ_PRIMid_Real);
		/*@Nullable*/ Iterator<?> ITERATOR__1 = BOXED_components.iterator();
		/*@NonNull*/ /*@Thrown*/ SequenceValue collect;
		while (true) {
		    if (!ITERATOR__1.hasNext()) {
		        collect = accumulator;
		        break;
		    /*@Nullable*/ /*@NonInvalid*/ Component _1 = (Component)ITERATOR__1.next();
		     * weight
		    if (_1 == null) {
		        throw new InvalidValueException("Null source");
		    final /*@NonNull*/ /*@Thrown*/ Number weight = _1.getWeight();
		    final /*@NonNull*/ /*@Thrown*/ RealValue BOXED_weight = ValuesUtil.realValueOf(weight);
		    accumulator.add(BOXED_weight);
		final /*@NonNull*/ /*@Thrown*/ RealValue sum = (RealValue)CollectionSumOperation.INSTANCE.evaluate(evaluator, TypeId.REAL, collect);
		final /*@NonNull*/ /*@Thrown*/ Number UNBOXED_sum = sum.asNumber();
		return (Double)UNBOXED_sum;
The last line is wrong (the cast) and will produce a ClassCastException when an instance of the model is validated (or when the property view is retrieving the value of actualWeight, but this is internally ignored, instead the value is simply not visible). This problem also occurs when generating Delegates instead of Java code for OCL constraints.
The last line should in fact be:
return UNBOXED_sum.doubleValue();
I have some other code which is similar (a method body which is also supposed to return an ecore::EDouble) for which this is generated properly, so I think this is very specific to the scenario that I'm having here.
Any idea what might cause the problem ?
Cédric
Re: ClassCastException thrown when using ecore::EDouble [message #1067910 is a reply to message #1067896] Thu, 11 July 2013 04:34 Go to previous messageGo to next message
When you have such a good repro, please raise a Bugzilla.
Ed Willink
On 11/07/2013 08:36, Cedric Moonen wrote:
> Hi Ed,
> class Container
> ->sum();
> invariant validWeight('The actual weight exceeds the required weight'): if actualWeight> requiredWeight
> then null
> else true
> endif;
> class Component
> while (true) {
> break;
> * weight
> if (_1 == null) {
> Cédric
Re: ClassCastException thrown when using ecore::EDouble [message #1067923 is a reply to message #1067910] Thu, 11 July 2013 05:16 Go to previous message
Ok done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=412736
Previous Topic:Debugging OCL constraints via java debugger
Next Topic:How to get OCL variable from Java code
Current Time: Sun Jul 27 08:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.07300 seconds
