CSS Validation [message #1005557] |
Sat, 26 January 2013 12:10  |
I don't know if this is a bug or configuration issue on my part, but I downloaded the lastest build of xtend yesterday (2.4.0.v201301250856), and I am getting hundreds of this error in all of my CSS files:
extraneous input ' ' expecting RULE_IDENT {...} Xtext Check (fast)
It seems that any css rules that have '.' in the number cause this error, such as:
Furthermore, there does not seem to be a way to turn of the validation on the css files.
Has anybody else seen this issue?
Re: CSS Validation [message #1005743 is a reply to message #1005727] |
Mon, 28 January 2013 08:46   |
No offense taken ;-) - I guess because the parser is generated upgrading
Xtext to 2.4.0 can't lead to such a problem. So if it works with 2.3.1
it will still work with 2.4.0.
Knowing what Steven has installed would help to find out who is the one
to blame.
Tom
Am 28.01.13 13:31, schrieb Sebastian Zarnekow:
> Sorry Tom, didn't meant to blame e(fx)clipse for that one. The e4 css
> stuff sounds more likely to cause the issue.
> Regards,
> Sebastian
> Am 28.01.13 13:20, schrieb Tom Schindl:
>> e(fx)clipse is perfectly happy with .9em and translate it to what it is
>> 0.9em ;-) but I'm running with xtext 2.3.1 have not yet tried 2.4.0.
>> It could also be the e4 css editor, which is also based on xtext
>> Tom
>> Am 28.01.13 09:55, schrieb Sebastian Zarnekow:
>>> Am 27.01.13 15:07, schrieb Steven Spungin:
>>>> I do not see any installed plugin with xtext and css in the name.
>>>> Which
>>>> feature would have (or should have) installed the css validator?
>>> Probably e(fx)clipse? I'm not sure - don't know each and every
>>> application of Xtext.
>>> Regards,
>>> Sebastian
Re: CSS Validation [message #1005871 is a reply to message #1005743] |
Tue, 29 January 2013 02:18   |
Hi Tom,
yes, upgrading to 2.4.0 but still using e(fx)clipse that was compiled to
2.3.1 will lead to all sorts of problems but not this one :-)
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 28.01.13 14:46, schrieb Tom Schindl:
> to blame.
> Tom
>> Regards,
>> Sebastian
>>> Tom
>>>>> Which
>>>> Regards,
>>>> Sebastian
Re: CSS Validation [message #1067857 is a reply to message #1005557] |
Wed, 10 July 2013 18:05  |
I'm a bit confused. Did anyone figure out the problem?
I'm having a very similar issue. With e(fx)clipse installed on Eclipse Java EE. I have tried it with only the "e(fx)clipse - Composite - FX Tooling" and get the same results. It says:
Unknown property: "text-decoration"
for this code:
a:link
{ text-decoration: none; color: #ff0000 }
It seems like it's a problem between the EE css plugin and the fx css plugin. If I uninstall fx, the problem goes away. I have to reopen the .css file because it says:
No editor descriptor for id at.bestsolution.efxclipse.tooling.css.CssDsl
but after I reopen it, everything is back to normal. I can once again view the css file with syntax highlighting. It's just obviously lacking the other great qualities I was hoping to get from e(fx)clipse.
FUDForum. Page generated in 0.09759 seconds
