Home » Modeling » Graphiti » autoupdate(autoupdate the diagram in case of changes in datamodel)
autoupdate [message #1067759] Wed, 10 July 2013 09:19 Go to next message
Hi all,
I have an EMF Datamodel.
In case of changes in datamodel the method "updateneeded" is random called. Therefor I have a listener. This listener calls the method "update" in case of changes.
The method is called and I can define the differences. But if I want to add anything to the diagram an exception is thrown.
Has anyone an idea how I could autoupdate the diagram?
Here is my code:
In the listener:
UpdateContext updateContext = new UpdateContext(getDiagram().getChildren().get(0).getGraphicsAlgorithm().getPictogramElement());
IUpdateFeature updateFeature = getFeatureProvider().getUpdateFeature(updateContext);
updateFeature.update(updateContext);
and that's the exception:
!ENTRY org.eclipse.ui 4 0 2013-07-11 13:36:43.886
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.IllegalStateException: Cannot modify resource set without a write transaction)
Caused by: java.lang.IllegalStateException: Cannot modify resource set without a write transaction at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting
Regards, Juliane
[Updated on: Thu, 11 July 2013 08:05] by Moderator
Re: autoupdate [message #1068134 is a reply to message #1067759] Fri, 12 July 2013 06:50 Go to previous message
Juliane,
there's a bunch of isAutoUpdateAt... methods in the diagram type provider
that you might override to control the update behavior of the editor. Have
you seen those? Implementing an update listener should not be necessary
here.
Michael
Previous Topic:Save exception - UnknownServiceException
Next Topic:updateNeeded preconditions
Current Time: Wed Jul 23 04:23:17 EDT 2025
Powered by FUDForum. Page generated in 0.10327 seconds
