Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Maven Dependencies?
Maven Dependencies? [message #106270] |
Sun, 06 January 2008 23:25  |
(I hope this does not come across twice - I don't see the first one so I'm keeping my fingers crossed)
I'm trying to get a basic setup working for Teneo and Hibernate. I was wondering if anyone knows of a maven 2 repository housing the necessary dependencies?
- Ole
Re: Can't load HbMapperException with Hibernate Setup [message #106818 is a reply to message #106782] |
Tue, 15 January 2008 00:57   |
Hi Ole,
Contributions are always appreciated! If you want to update the docs there are two ways:
- create a bugzilla and mark all the things you missed/want to change in the docs in that bugzilla
then I can add it in the docs myself, or
- check out the org.eclipse.emf.teneo.website project, the docs are in apache forest. When you
change them just make a patch and send it as a bugzilla
gr. Martin
Ole Ersoy wrote:
> OK - I think I found it. It's in the
> org.eclipse.emf.teneo.hibernate.mapper_0.8.0.v200712280940 plugin. I'll
> be glad to update library tutorial, etc. as I'm going along. Please let
> me know of any additional steps I can take to contribute.
> Cheers,
> - Ole
> Ole Ersoy wrote:
>> Hi,
>> I'm trying to hibernate setup and the class loader does not see:
>> org.eclipse.emf.teneo.hibernate.HbMapperException;
>> I verified that these are on the class path:
>> * org.eclipse.emf.teneo
>> * org.eclipse.emf.teneo.annotations
>> * org.eclipse.emf.teneo.hibernate
>> Are there other dependencies needed?
>> Thanks,
>> - Ole
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Can't load HbMapperException with Hibernate Setup [message #106878 is a reply to message #106818] |
Tue, 15 January 2008 15:23   |
Hi Martin,
Super - Thanks for the heads up. I'll submit a patch asap.
- Ole
Martin Taal wrote:
> Hi Ole,
> there are two ways:
> the docs in that bugzilla then I can add it in the docs myself, or
> apache forest. When you change them just make a patch and send it as a
> bugzilla
> gr. Martin
>> I'll be glad to update library tutorial, etc. as I'm going along.
>> Please let me know of any additional steps I can take to contribute.
>> Cheers,
>> - Ole
>> Ole Ersoy wrote:
>>> Hi,
>>> Thanks,
>>> - Ole
Re: Setting VARCHAR Length by EAnnotation? [message #107070 is a reply to message #106958] |
Wed, 16 January 2008 10:37  |
Hi Martin,
Super - I'll give the column annotation a shot. I looked around for a global varchar default for hibernate as well, and came up short, so I guess it's hard coded. I did put in a bugzilla feature request for a global teneo varchar limit default.
Thanks again,
- Ole
Martin Taal wrote:
> Hi Ole,
> For each individual eattribute you can set a column annotation with a
> length.
> However, there is currently no global default varchar length setting. I
> tried to find a global hibernate parameter to set the column length but
> I could not find it.
> Can you enter a bugzilla feature request for this?
> gr. Martin
> Ole Ersoy wrote:
>> Hi,
>> Just wondering if anyone knows whether it's possible to change the
>> default VARCHAR length through the use of an EAnnotation? The
>> "Developer Use Case" would be the creation of a dynamic model and
>> generating the corresponding database schema.
>> Thanks,
>> - Ole
Re: Maven Dependencies? [message #613935 is a reply to message #106287] |
Mon, 07 January 2008 00:56  |
Hi Ole,
Teneo can be run outside of Eclipse. I use it myself in a webapp.
See here:
http://www.elver.org/hibernate/installation.html#Installing+ the+runtime+layer+in+a+non-plugin+EMF+project
In addition Teneo requires the following jars:
- org.eclipse.emf.ecore.jar, org.eclipse.emf.ecore.xmi.jar, org.eclipse.emf.common.jar. These jars
can be found in the plugins directory in your eclipse installation.
- the relevant hibernate or jpox jars
- commons-logging jar
As far as I know Teneo is not present in a maven respository, I do not know if the other
dependencies are present somewhere in maven repositories.
gr. Martin
Ole Ersoy wrote:
> One more question...Does teneo 0.80 have to be run inside / depend on
> eclipse?
> - Ole
The Netherlands
Re: Maven Dependencies? [message #613949 is a reply to message #106301] |
Mon, 07 January 2008 10:36  |
Hi Martin,
Super - Thanks. I'll give it a go.
- Ole
Martin Taal wrote:
> Hi Ole,
> See here:
> org.eclipse.emf.common.jar. These jars can be found in the plugins
> know if the other dependencies are present somewhere in maven repositories.
> gr. Martin
>> eclipse?
>> Thanks,
>> - Ole
Can't load HbMapperException with Hibernate Setup [message #613981 is a reply to message #106382] |
Mon, 14 January 2008 12:46  |
- Ole
Re: Can't load HbMapperException with Hibernate Setup [message #613982 is a reply to message #106766] |
Mon, 14 January 2008 15:16  |
OK - I think I found it. It's in the org.eclipse.emf.teneo.hibernate.mapper_0.8.0.v200712280940 plugin. I'll be glad to update library tutorial, etc. as I'm going along. Please let me know of any additional steps I can take to contribute.
- Ole
Ole Ersoy wrote:
> - Ole
Re: Can't load HbMapperException with Hibernate Setup [message #613985 is a reply to message #106782] |
Hi Ole,
gr. Martin
> Cheers,
> - Ole
> Ole Ersoy wrote:
>> Hi,
>> Thanks,
>> - Ole
The Netherlands
Re: Can't load HbMapperException with Hibernate Setup [message #613989 is a reply to message #106818] |
Hi Martin,
- Ole
Martin Taal wrote:
> Hi Ole,
> there are two ways:
> bugzilla
> gr. Martin
>> Cheers,
>> - Ole
>> Ole Ersoy wrote:
>>> Hi,
>>> Thanks,
>>> - Ole
Setting VARCHAR Length by EAnnotation? [message #613990 is a reply to message #106878] |
Tue, 15 January 2008 21:06  |
Just wondering if anyone knows whether it's possible to change the default VARCHAR length through the use of an EAnnotation? The "Developer Use Case" would be the creation of a dynamic model and generating the corresponding database schema.
- Ole
Re: Setting VARCHAR Length by EAnnotation? [message #613995 is a reply to message #106890] |
Wed, 16 January 2008 05:15  |
Hi Ole,
For each individual eattribute you can set a column annotation with a length.
However, there is currently no global default varchar length setting. I tried to find a global
hibernate parameter to set the column length but I could not find it.
gr. Martin
Ole Ersoy wrote:
> - Ole
The Netherlands
Re: Setting VARCHAR Length by EAnnotation? [message #614003 is a reply to message #106958] |
Hi Martin,
Thanks again,
- Ole
Martin Taal wrote:
> Hi Ole,
> length.
> gr. Martin
> Ole Ersoy wrote:
>> Hi,
>> Thanks,
>> - Ole
Current Time: Sat Jul 26 11:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.50020 seconds
