Home » Language IDEs » C / C++ IDE (CDT) » Eclipse for Java and C++(Loading more eclipse)
Eclipse for Java and C++ [message #1067587] Tue, 09 July 2013 09:06 Go to next message
Hi. I loaded eclipse IDE and eclipse JEE on my Windows 7 Pro lap top. Very impressed.
HHowever I now want to use C++.
Can I add C++ to the eclipse IDE or do I need to load another. The later I tried but it didn't work - but before I get knee deep I thought I'd ask you guys the approach.
Any help gratefully appreciated. Cheers
Re: Eclipse for Java and C++ [message #1067598 is a reply to message #1067587] Tue, 09 July 2013 10:02 Go to previous messageGo to next message
Nigel,
You can certainly add features to your existing Eclipse installation, it was specifically designed for that. Here are the instructions: http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.platform.doc.user%2Ftasks%2Ftasks-124.htm
By the way, there is a link to these instructions on the Eclipse Downloads page. It's labeled "Compare & Combine Packages."
Re: Eclipse for Java and C++ [message #1067606 is a reply to message #1067598] Tue, 09 July 2013 10:37 Go to previous messageGo to next message
Eric first thanks, at least I know I'm going in the right direction.
However I get
Cannot complete the install because one or more required items could not be found.
Software being installed: XL C/C++ Compiler Support SDK 6.1.1.201302132326 (org.eclipse.cdt.xlc.sdk.feature.group 6.1.1.201302132326)
or if I try just CDT I get
Software being installed: C/C++ Development Tools 8.1.2.201302132326 (org.eclipse.cdt.feature.group 8.1.2.201302132326)
Missing requirement: C/C++ Development Tools UI 5.5.0.201302132326 (org.eclipse.cdt.ui 5.5.0.201302132326) requires 'bundle
I assumed as java works and I have g++ that I was in good shape.
Any thoughts? Cheers
Re: Eclipse for Java and C++ [message #1067619 is a reply to message #1067606] Tue, 09 July 2013 11:18 Go to previous messageGo to next message
I don't know off the top of my head, but I'll move this topic to the CDT forum section where you'll probably get a more focused audience. I suggest you also reply with the details of your Eclipse version and what exact steps you've tried.
Re: Eclipse for Java and C++ [message #1067629 is a reply to message #1067619] Tue, 09 July 2013 12:56 Go to previous messageGo to next message
Many tx Eric.
I have loaded on my Windows
Eclipse IDE for Java Developers
Version: Indigo Service Release 2
Build id: 20120216-1857
I went help->Install software -> Selected all available sites and was offered CDT Main Features and CDT optional features.
I selected and clicked next to get the above errors.
If anyone can suggest next step it would be much appreciated.
I'll try an uninstall and starting again with C++ and Java a bit later without other input as I guess that will resolve the problem. But I asume I can update eclipse in situ if that is the issue?
Cheers
Re: Eclipse for Java and C++ [message #1068533 is a reply to message #1067629] Sat, 13 July 2013 12:09 Go to previous messageGo to next message
CDT 8.1.2 won't work on Indigo. 8.0.2 is that last version that will work. To install it, select the Indigo update site (Work it: Indigo), under Programming languages, select C/C++ Development Tools 8.0.2.
Re: Eclipse for Java and C++ [message #1068535 is a reply to message #1068533] Sat, 13 July 2013 12:13 Go to previous message
To get started with C++ on Windows. Check out this page:
http://help.eclipse.org/indigo/topic/org.eclipse.cdt.doc.user/concepts/cdt_c_before_you_begin.htm
You might already have what you need but it's good to double check.
[Updated on: Sat, 13 July 2013 12:13] by Moderator
Previous Topic:Eclipse SDK 3.72 with plugin C/C++ windows 7 32bit
Next Topic:AVR Support Disappeared
Current Time: Sun Aug 31 14:56:02 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
