BrowserWidget, JQuery document.ready and BrowserFunctions [message #1067613] |
Tue, 09 July 2013 10:55  |
We use a jquery-based calendar script wrapped by a BrowserWidget in RCP.
When we tried it in RAP it didn't work.
The reason is that the calendar script calls a BrowserFunction in the document.ready like this:
$(document).ready(function () {
theJavaFunction();
But at this time "theJavaFunction", which is a SWT-BrowserFunction is not yet available. When i call it later, like when i click a button, it works fine.
I wrote a small snippet to reproduce the error, its attached to this post.
Should i file a bug?
Is there a workaround?
Thanks in advance,
Stefan
Re: BrowserWidget, JQuery document.ready and BrowserFunctions [message #1067700 is a reply to message #1067613] |
Wed, 10 July 2013 03:52   |
Hi Stefan,
BrowserFuction is attached to the client document in the document
"onload" event. According to JQuery documentation the .ready() function
is not compatible with body onload event (see [1]). You could try the
JQuery .load() function instead as suggested in the documentation.
[1] http://api.jquery.com/ready/
HTH,
Ivan
On 7/9/2013 5:55 PM, Stefan M wrote:
> theJavaFunction();
> Thanks in advance,
> Stefan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: BrowserWidget, JQuery document.ready and BrowserFunctions [message #1067905 is a reply to message #1067613] |
Thu, 11 July 2013 04:06   |
Hi.
The problem here, I think, is that both your script and RAP try to do
something on the load event. RAP attaches the browserFunctions, your
script calls them. But since your script runs inside the iframe it's
called first. SWT/RCP does has better control over the browser widget
and can probably make sure it's notified first. To fix this, simply put
your code in a timeout:
window.setTimeout( callTheJavaFunction, 0 );
Greetings,
Tim
Am 09.07.2013 16:55, schrieb Stefan M:
> theJavaFunction();
> Thanks in advance,
> Stefan
Tim Buschtöns
FUDForum. Page generated in 0.05237 seconds
