Home » Modeling » M2T (model-to-text transformation) » use Generated file in memory directly
use Generated file in memory directly [message #1067592] Tue, 09 July 2013 09:45 Go to next message
Hi all ,
I want guidance please about xpnad generation procedure. I worte xpand template to generate another xpand template and I want to run the generated template when it is still in memory without writing it to disk .
I appreciate your guidance .
Thanks in advance.
[Updated on: Tue, 09 July 2013 09:57] by Moderator
Re: use Generated file in memory directly [message #1067834 is a reply to message #1067592] Wed, 10 July 2013 15:19 Go to previous messageGo to next message
the following works for me but i dont know if it will work in all cases
		final Template template = XpandParseFacade.file(new StringReader("«DEFINE test FOR String»«FILE 'x.text'»Hallo «this»!«ENDFILE»«ENDDEFINE»"), "test/Test.xpt");
		Output out = new OutputImpl();
		out.addOutlet(new Outlet("my-gen"));
		ResourceManager resourceManager = new ResourceManagerDefaultImpl() {
		public Resource loadResource(String fullyQualifiedName,
				String extension) {
			if ("test::Test".equals(fullyQualifiedName)){
				return template;
			return super.loadResource(fullyQualifiedName, extension);
		ProtectedRegionResolver prs = null;
		ProgressMonitor monitor = new NullProgressMonitor();
		ExceptionHandler exceptionHandler = null;
		NullEvaluationHandler nullEvaluationHandler = null;
		VetoableCallback callback = null;
		XpandExecutionContext execCtx = new XpandExecutionContextImpl(resourceManager , out, prs, new HashMap<String, Variable>(), monitor, exceptionHandler, nullEvaluationHandler, callback);
		XpandFacade.create(execCtx).evaluate("test::Test::test", "xxx");
Re: use Generated file in memory directly [message #1067839 is a reply to message #1067834] Wed, 10 July 2013 15:30 Go to previous messageGo to next message
The following works as well
import java.io.InputStream;
import org.eclipse.emf.mwe.core.resources.AbstractResourceLoader;
import org.eclipse.emf.mwe.core.resources.ResourceLoaderFactory;
import org.eclipse.emf.mwe.internal.core.MWEPlugin;
import org.eclipse.xpand2.XpandExecutionContext;
import org.eclipse.xpand2.XpandExecutionContextImpl;
import org.eclipse.xpand2.XpandFacade;
import org.eclipse.xpand2.output.Outlet;
import org.eclipse.xpand2.output.Output;
import org.eclipse.xpand2.output.OutputImpl;
import org.eclipse.xtext.util.StringInputStream;
public class TestIt {
	public static class MyRL extends AbstractResourceLoader {
		protected Class<?> tryLoadClass(String clazzName)
				throws ClassNotFoundException {
			return MWEPlugin.loadClass(MWEPlugin.ID, clazzName);
		public InputStream getResourceAsStream(String path) {
			if ("test/Test.xpt".equals(path)) {
				return new StringInputStream("«DEFINE test FOR String»«FILE 'x.text'»Halloooooo «this»!«ENDFILE»«ENDDEFINE»");
			return super.getResourceAsStream(path);
		System.setProperty(ResourceLoaderFactory.PARAM_RESOURCELOADER_CLASS, MyRL.class.getName());
		XpandExecutionContext execCtx = new XpandExecutionContextImpl(out, null);
Re: use Generated file in memory directly [message #1071153 is a reply to message #1067839] Fri, 19 July 2013 09:01 Go to previous messageGo to next message
Hi Christian ,
Thank you for your answer .
but As I understood from your answer , it is implementing xpnad code without need to physiacl template file and its workflow am I right ?
what I need actually is generating templates and files to memory , then use these template and file to final generation to disk .
for example :
String wfFile2 = "workflow/generator.mwe";
		properties2.put("modelFile", modelFilePath);
		properties2.put("src-gen", src-gen);
if you please How I can make src-gen position in memory and how I access the generated template there ?
in the next step :
String wfFile3 = "workflow/generator2.mwe";
		properties2.put("src-gen", folderondisk or workspace);
generator2.mwe should run on the generated template in memory .
anothee question please : why my plugin can not find the generated template when I specify local folder to keep the generated template?
to make it simple I am looking for : what is the best way to implement template in plugin and reusing genertaed templte in the same plugin ?
any guidance or tutorial for better understanding or examples are appreciated
Thanks in advance
Re: use Generated file in memory directly [message #1071168 is a reply to message #1071153] Fri, 19 July 2013 09:38 Go to previous message
Hi sorry no tutorial but my Code does what you ask for (OK my
template is hard coded but this does not count)
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:JET Editor in Kepler
Next Topic:[XPAND] Define EMF metamodel From XML with XPand
Current Time: Sat Jul 26 10:11:18 EDT 2025
Powered by FUDForum. Page generated in 0.09700 seconds
