Discouraged Access [message #1067408] |
Mon, 08 July 2013 10:31  |
Kepler 64 bit windows
I am following Lars' tutorial (book and article from 4 days ago have same code) and adding a popup menu. However when I add the import
import org.eclipse.e4.ui.workbench.swt.modeling.EMenuService;
I get
Description Resource Path Location Type
Discouraged access: The type EMenuService is not accessible due to restriction on required library C:\eclipse\Kepler64\eclipse\plugins\org.eclipse.e4.ui.workbench.swt_0.12.0.v20130517-0139.jar HomePage.java /swb3/src/swb3/parts line 20 Java Problem
Has the popup menu registration process changed
FUDForum. Page generated in 0.06761 seconds
