Home » Archived » Test and Performance Tools Platform (TPTP) » When AGR resolvers are not used....
When AGR resolvers are not used.... [message #106750] Thu, 26 July 2007 15:13 Go to next message
Originally posted by: joel_patterson.verizon.net
I was experimenting with resolvers and removed the entry from plugin.xml
for the NonTrivialWidgetResolver. I expected everything to be forced
through the AdaptiveResolver (or just not work) but when working with a
Tree I saw:
<command descriptive="NORMAL (289)" type="item-select"
contextId="view/com.agitar.eclipse.outcomes.views.OutcomesView "
widgetId="org.eclipse.swt.widgets.Tree#1">
<item path="com.agitar.result.outcome.r0|0||0|"/>
</command>
Since a resolver wasn't used here, how did this value get created -- and
if I wanted to use something like this for a Tree instead of the
NonTrivialWidgetResolver, what would I call? Obviously the method to
get this value exists somewhere...
Re: When AGR resolvers are not used.... [message #106765 is a reply to message #106750] Thu, 26 July 2007 16:30 Go to previous message
Hi Joel,
The widgetId in this case comes from the 'defaultControlId' which is
computed when the widgetId returned from the widget resolvers is null.
The item path comes from the 'defaultItemAttributes', computed when the
widget is not found with a resolver.
If you want to use these methods in a custom widget resolver, the method
findTreeItemInx can be found in the AbstractStructuredCommand class and the
computeDefaultControlId method is found in the MacroUtil class.
I hope this helps.
Sincerely,
Liz Dancy
"Joel Patterson" <joel_patterson@verizon.net> wrote in message
news:f8aros$1cg$1@build.eclipse.org...
>Tree I saw:
> </command>
> NonTrivialWidgetResolver, what would I call? Obviously the method to get
Previous Topic:AGR suites in JUnit
Next Topic:TPTP profiler using SSH tunnel
Current Time: Sat Jul 19 01:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.26511 seconds
