Home » Modeling » EMF » Interface optimization
Interface optimization [message #1067466] |
Mon, 08 July 2013 16:02  |
Given a simple model such as:
package my : my = 'my'
class A
operation op() : String[?];
class B extends A
Clearly A::op() must appear in A.java and AImpl.java, but is there a way
to avoid B::op() appearing in both B.java and BImpl.java (when
BImpl.java is sufficient)?
This optimization becomes quite significant when examing the amount of
generated into initializePackageContents when there are many derived
implementations of an interface and when the operation has a complex
signature.
Ed Willink
Re: Interface optimization [message #1067471 is a reply to message #1067468] |
Mon, 08 July 2013 16:45   |
Thanks, SuppressedVisibility fixes the interface, but since it was the
metadata that is costing, it doesn't help.
Yes. My many derived implementations have distinctive bodies.
There is just one declaration A::op() in the interface. It may have many
derived implementations, but surely only the interface need appear in
the metadata?
Ed Willink
On 08/07/2013 21:21, Ed Merks wrote:
> Ed,
> An EAnnotation as produced by
> org.eclipse.emf.ecore.util.EcoreUtil.setSuppressedVisibility(EOperation,
> boolean) on B's declaration of op does the trick, in terms of the
> generated interface for B, but that has no impact on the amount of
> metadata in the Ecore model; there are two declarations and they must
> be represented as such. Unless you specify a body annotation for the
> declaration of op in B so that something useful (and different from
> AImpl)l is generated in BImpl, that declaration is kind of pointless...
> On 08/07/2013 10:02 PM, Ed Willink wrote:
>> Hi
>> class A
>> class B extends A
>> way to avoid B::op() appearing in both B.java and BImpl.java (when
>> of generated into initializePackageContents when there are many
>> derived implementations of an interface and when the operation has a
>> complex signature.
>> Regards
>> Ed Willink
Re: Interface optimization [message #1067492 is a reply to message #1067471] |
Tue, 09 July 2013 01:40   |
Ed,
The metadata for each operation declaration is what carries the body and
it is needed by eInvoke. Even in Java the full metadata for the
signature is duplicated in each and every method declaration and
definition, even across the interface's declaration and the classes
definition. If it's byte code reduction for package initialization you
seek, Initialize by Loading accomplishes that purpose quite
effectively. If it's the memory footprint of the model itself you seek
to minimize, it's hard to imagine that the size of the metamodel will
generally be significant relative to the size of all the instances...
On 08/07/2013 10:45 PM, Ed Willink wrote:
> Hi
> many derived implementations, but surely only the interface need
> appear in the metadata?
> Regards
> Ed Willink
>> Ed,
>>> Hi
>>> class A
>>> class B extends A
>>> complex signature.
>>> Regards
>>> Ed Willink
Re: Interface optimization [message #1067493 is a reply to message #1067492] |
Tue, 09 July 2013 01:53   |
Hi Ed
My main concern is the extra start up time of 8 object/8 lines of
initialization for each of the derived operations. The extra code is a
secondary concer. Initialize by loading just makes the startup time even
worse.
At present the derived methods have all been manually pasted with an
@generated NOT so they have no modeling overhead. Attempting to replace
the manual pastes by modeled autogeneration incurs this unexpected
modeling overhead. It seems that Class/insert.javajetinc will be a much
better solution for unmodeled autogeneration.
Ed Willink
On 09/07/2013 06:40, Ed Merks wrote:
> Ed,
> and it is needed by eInvoke. Even in Java the full metadata for the
> you seek, Initialize by Loading accomplishes that purpose quite
> seek to minimize, it's hard to imagine that the size of the metamodel
> will generally be significant relative to the size of all the
> instances...
>> Hi
>> the metadata that is costing, it doesn't help.
>> Regards
>> Ed Willink
>>> Ed,
>>> must be represented as such. Unless you specify a body annotation
>>> for the declaration of op in B so that something useful (and
>>> different from AImpl)l is generated in BImpl, that declaration is
>>>> Hi
>>>> class A
>>>> class B extends A
>>>> a way to avoid B::op() appearing in both B.java and BImpl.java
>>>> (when BImpl.java is sufficient)?
>>>> a complex signature.
>>>> Regards
>>>> Ed Willink
Re: Interface optimization [message #1067500 is a reply to message #1067493] |
Tue, 09 July 2013 02:26  |
Ed,
Are your concerns based on measurements or is it of an abstract nature?
One could imagine using binary serialization to avoid the cost of
parsing XML and to reduce the serialized footprint, but in the end, yes,
the same instances need to be constructed one way or the other, and yes
these instances are needed, so no, they can't be optimized away.
On 09/07/2013 7:53 AM, Ed Willink wrote:
> Hi Ed
> even worse.
> replace the manual pastes by modeled autogeneration incurs this
> unexpected modeling overhead. It seems that Class/insert.javajetinc
> will be a much better solution for unmodeled autogeneration.
> Regards
> Ed Willink
>> Ed,
>> instances...
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Ed,
>>>>> Hi
>>>>> class A
>>>>> class B extends A
>>>>> amount of generated into initializePackageContents when there are
>>>>> many derived implementations of an interface and when the
>>>>> operation has a complex signature.
>>>>> Regards
>>>>> Ed Willink
Current Time: Wed Jul 30 21:50:56 EDT 2025
Powered by FUDForum. Page generated in 0.03604 seconds
