Home » Eclipse Projects » Eclipse 4 » Deleting a part from a model
Deleting a part from a model [message #1067452] Mon, 08 July 2013 15:03 Go to next message
I have a situation where I use the PartService's createPart() method to create a part from a PartDescriptor. The PartDescriptor indicates that the part is "multiple", "closeable", and "dirtyable".
My problem is that when I then close the part, I see in the workbench.xmi that there is still an entry for the part, with toBeRendered="false". That orphaned entry isn't really doing me any good because I don't want to retrieve it again.
Is there a way I can tell the model to remove the part entirely when it is closed? I'm sure there must be, but I can't find the API in either the EPartService or EModelService.
Thank you.
Re: Deleting a part from a model [message #1067453 is a reply to message #1067452] Mon, 08 July 2013 15:09 Go to previous messageGo to next message
My, how often the answer comes just after posting to a forum....
Calling setParent(null) on the part did the trick.
Re: Deleting a part from a model [message #1067457 is a reply to message #1067453] Mon, 08 July 2013 15:29 Go to previous messageGo to next message
The real solution is to tag the part with "removeOnHide" and the
framework will remove the instance from the model when closed.
Tom
Re: Deleting a part from a model [message #1067515 is a reply to message #1067457] Tue, 09 July 2013 04:08 Go to previous messageGo to next message
I put removeOnHide into eclipse help (F1) but it finds no matches. Is there a list of these tags somewhere. I am assuming I just add it to the Tags on the supplementary tag of the part descriptor.
Re: Deleting a part from a model [message #1067528 is a reply to message #1067515] Tue, 09 July 2013 04:45 Go to previous messageGo to next message
It is on the EPartService. I currently don't know if this is documented
in the wiki else this should be done there. Naturally also the tooling
should know the tags available - you should file a bug against it unless
there's already one.
Tom
Re: Deleting a part from a model [message #1067565 is a reply to message #1067528] Tue, 09 July 2013 07:09 Go to previous message
https://bugs.eclipse.org/393870
M.
Previous Topic:[Kepler] Cannot resolve org.eclipse.e4.ui.model.application.*
Next Topic:Discouraged Access
Current Time: Sat Jul 26 19:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.26807 seconds
