Home » Language IDEs » Java Development Tools (JDT) » Unable to evaluate the selected expression(Unable to evaluate the selected expression)
Unable to evaluate the selected expression [message #799664] Thu, 16 February 2012 01:39 Go to next message
I am on eclipse indigo.
In debug mode, when i try to inspect variables, it gives me the error "Unable to evaluate the selected expression".
I notice that instead of opening the class file it is opening the java source file where it gives the above error on inspect.
I verified that the source is properly attached to the class files.
The variables tab is working fine just that the inspect does not seems to work.
Please let me know if you need any more info.
Re: Unable to evaluate the selected expression [message #1067444 is a reply to message #799664] Mon, 08 July 2013 14:04 Go to previous messageGo to next message
Did you ever figure this out? I've run into the same issue.
Re: Unable to evaluate the selected expression [message #1696908 is a reply to message #1067444] Fri, 29 May 2015 06:27 Go to previous message
i have problem like it
Previous Topic:Bug when I run a current project
Next Topic:get Eclipse console print message by dll
Current Time: Sat Jul 26 03:25:35 EDT 2025
Powered by FUDForum. Page generated in 0.04824 seconds
