Home » Eclipse Projects » Eclipse 4 » Exception Workbench has not been created yet(With Eclipse 4 Application)
Exception Workbench has not been created yet [message #1067414] Mon, 08 July 2013 10:43 Go to next message
I have created an RCP application with E4 Application model, it's work fine but when a i try to get some Workbench ressources i get a java.lang.IllegalStateException: Workbench has not been created yet.
For example when calling
PlatformUI.getWorkbench().getDisplay();
from what I read this is due to the lazy instantiation, Can someone tell me how to instantiate the workbench, I need to impélmentation some selection Dialog
Trace
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalStateException: Workbench has not been created yet.
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1057)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4170)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:138)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:162)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
	at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:93)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.createViewMenu(FilteredItemsSelectionDialog.java:549)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.createHeader(FilteredItemsSelectionDialog.java:478)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.createDialogArea(FilteredItemsSelectionDialog.java:655)
	at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:775)
	at org.eclipse.jface.window.Window.create(Window.java:432)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1104)
	at org.eclipse.ui.dialogs.SelectionStatusDialog.create(SelectionStatusDialog.java:153)
	at org.eclipse.ui.dialogs.FilteredItemsSelectionDialog.create(FilteredItemsSelectionDialog.java:355)
	at org.eclipse.jface.window.Window.open(Window.java:791)
	at dz.iaityahia.cieptalcars.matresorerie.handlers.ExportToExcelAction.execute(ExportToExcelAction.java:17)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 33 more
Re: Exception Workbench has not been created yet [message #1463466 is a reply to message #1067414] Thu, 06 November 2014 10:40 Go to previous messageGo to next message
Did you ever get an answer to this or figure out how to resolve it? I am having the same issue and would like to know how you worked around it. Much appreciated....
Re: Exception Workbench has not been created yet [message #1470331 is a reply to message #1463466] Wed, 12 November 2014 03:55 Go to previous messageGo to next message
The PlatformUI.getWorkbench() is a Eclipse 3.x method. If you are in a pure E4 application, you must not depend on org.eclipse.ui and you will not be able to call this method.
If you need to get the Display or current IWorkbench (which would be an E4 workbench), you must inject it where you need it, or you can get the Display using Display.getCurrent().
icon5.gif  Re: Exception Workbench has not been created yet [message #1695929 is a reply to message #1470331] Wed, 20 May 2015 07:21 Go to previous messageGo to next message
I am injecting the E4 Workbench (org.eclipse.e4.ui.workbench), but I still get a "Workbench has not been created yet". Is there anything else you have to do other than injecting it?
Thanks.
Re: Exception Workbench has not been created yet [message #1696001 is a reply to message #1695929] Thu, 21 May 2015 01:57 Go to previous message
The question is, when are you trying to inject? Looks like you are trying to early in the startup process.
Previous Topic:"No repository found containing" error while generating P2
Next Topic:containerData effectively deprecated?
Current Time: Sun Jul 20 10:11:48 EDT 2025
Powered by FUDForum. Page generated in 0.04793 seconds
