Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Howto create a reference to an attribute?
Howto create a reference to an attribute? [message #1067078] Fri, 05 July 2013 13:32 Go to next message
I have an EClass "Person" that has several attributes (like name, age, etc.).
And another EClass "PDFTemplate" (same model) has EClass children like HLine, VLine, Box, etc.
I want a template sub-element "TextReference" that has a reference to one attribute of the Person.
My goal is to print the attribute to a PDF.
I can't imagine how I can create such a reference with EMF and I couldn't find a documentation for this.
For the user in my ECP application I would like to have a combobox or popup with all available attributes (tree or list).
What is the best way to create something like that in an ECore-Model?
Daniel
Re: Howto create a reference to an attribute? [message #1067084 is a reply to message #1067078] Fri, 05 July 2013 14:03 Go to previous messageGo to next message
Daniel,
Comments below.
On 05/07/2013 7:32 PM, Daniel Golesny wrote:
> Hi, I have an EClass "Person" that has several attributes (like name,
> age, etc.).
You don't reference an attribute...
You can reference a Person, or you can reference any old EObject, but
you can't reference just one feature of such a thing...
eObject.eClass().getEAllAttributes lists all the attributes of some object.
It's not so clear what exactly you're trying to do. If you really want
something that specifies a particular feature of some object, you'd need
two things: the reference to the object, and a reference to some
feature of that object (or an attribute with the name of that feature)...
> Daniel
Re: Howto create a reference to an attribute? [message #1067088 is a reply to message #1067084] Fri, 05 July 2013 14:40 Go to previous messageGo to next message
I have following EClasses:
Person
- name : EString
- age : EInt
- template : PDFTemplate
PDFTemplate
- elements[0..*] : ReferencedText
ReferencedText
- x : EFloat
- y : EFloat
- attributeReference : ?this here is my problem?
In the ECP Client I want to create a PDFTemplate instance with a child ReferencedText like this:
person1 => Person(name="Daniel Golesny",age=35, template=)
ReferencedText(x=50,y=100,attributeReference="person1->name")
I have a command "Generate PDF" which generates a PDF and I want to add the text "Daniel Golesny" to the pdf at position 50/100.
And the question is: What is the best way to get that or something similar?
Re: Howto create a reference to an attribute? [message #1067130 is a reply to message #1067088] Sat, 06 July 2013 03:49 Go to previous messageGo to next message
Daniel,
Comments below.
> Person
> - name : EString
> - age : EInt
> PDFTemplate
> ReferencedText
> - x : EFloat
> - y : EFloat
Think of how you'd do it in Java. You'd need two things. You'd need a
reference to the object with the value, and something to specify which
value of the object you want to access. Otherwise you'd just refer
directly to the value. It's no different in EMF. You need a reference
to the Person in your example and you'd need to know you wanted the
person's "name" feature.
> similar?
I'm not sure how general you want this to be. To be completely general
you'd have an EReference of type EObject and you could have an
EAttribute of type EString to specify the feature of that EObject you
want to display. You'd use eObject.eClass().getEAllAttributes() to
provide the valid choices for the features of the EObject in the derived
property descriptor for that. You'd need to choose the object before
choosing which feature of the object... Perhaps you'd have a property
descriptor for only one of the features and you'd display all the
choices of object/feature pairs and set both features with a single
compound command. Or perhaps you'd bring up a dialog for the feature:
http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_property_editor_in_a_generated_application
that lets the user choose the EObject that EObject's feature.
Re: Howto create a reference to an attribute? [message #1067194 is a reply to message #1067130] Sun, 07 July 2013 09:00 Go to previous messageGo to next message
Thank you very much, your explanation helped me a lot.
The reference to the Person was easy. I did it with a marker-interface "Referencable", so I could select all the entities I've marked.
The rest I will check later ... while playing around I'm sure that modelling a PDF by using a non-graphical editor is pain in the a**. Perhaps GEF would be better for that.
But I think I need some basics first before using GEF ...
Is there any up-to-date book or PDF about GEF? (or EMF with GEF)? All EMF books are many years old ...
Daniel
Re: Howto create a reference to an attribute? [message #1067198 is a reply to message #1067194] Sun, 07 July 2013 09:41 Go to previous message
Daniel,
Comments below.
You're welcome.
I'm not exactly sure what you mean...
I can imagine.
Yes, though project's like Graphiti and GMF are likely a better choice;
they make it easy to build a graphical editor for an EMF model...
Personally I'd start with Graphiti; it's being quite actively developed
further: http://www.eclipse.org/graphiti/
This isn't the GEF forum. :-P
> (or EMF with GEF)?
There's a redbook, but yes, it's quite old, and you probably don't want
to use GEF directly but rather reuse Graphiti or GMF.
EMF has evolved in a completely binary compatible way, so everything in
the EMF book is still valid today.
> Daniel
Previous Topic:Use only the editor from EMF Client Platform (ECP)
Next Topic:[CDO/EMF] Modeling BIG amounts of tiny data
Current Time: Fri Jul 25 19:54:26 EDT 2025
Powered by FUDForum. Page generated in 0.07437 seconds
