Home » Newcomers » Newcomers » "Could Not Write File" ?
"Could Not Write File" ? [message #1067123] Fri, 05 July 2013 22:00 Go to next message
I am trying to run the "Hello World!" application and when I click Run As > Java Application, a dialog box pops up with the following message:
Could not write file: /Users/kendaldale17/Documents/workspace/.metadata/.plugins/org.eclipse.debug.core/.launches.
Any ideas as to what to do to solve this problem?
Re: "Could Not Write File" ? [message #1067131 is a reply to message #1067123] Sat, 06 July 2013 03:51 Go to previous messageGo to next message
Kendall,
Have you tried editing that file directly? Typically something like
this means you either don't have permission or something else has opened
the file for writing and hasn't yet closed the output stream. Exiting
and restarting Eclipse might help.
Re: "Could Not Write File" ? [message #1067159 is a reply to message #1067131] Sat, 06 July 2013 16:23 Go to previous messageGo to next message
You're right, when I tried to restart Eclipse it gave me the error message of "See the log file" when I select which workspace to start working from. It directs me to the documents folder, but I can't find the /.metadata/.log file that it is directing me to look at.
Re: "Could Not Write File" ? [message #1067178 is a reply to message #1067159] Sun, 07 July 2013 03:46 Go to previous message
Kendall,
You can either edit that file directly in your OS or you can view it
using the Error Log view.
Previous Topic:Can not start eclipse !
Next Topic:Export Eclipse Comparision results
Current Time: Sat Nov 01 14:35:05 EDT 2025
Powered by FUDForum. Page generated in 0.08740 seconds
