Home » Archived » BIRT » Overflowing table in fixed layout
Overflowing table in fixed layout [message #1066589] Wed, 03 July 2013 06:43 Go to next message
I have recently started working on BIRT.
My issue is, I have chosen a fixed layout to display my grid.
The dataset fetch the data, is getting too many columns as in attachment
The number of columns in the table is dynamic .
Is it possible to divide a single table into as many additional tables as are required, based on no. of columns .
Ex. Can I specify that one table should have 10 columns extra columns to move in second table etc.
Main issue is no. of columns is dynamic
  • Attachment: BIRTIssue.doc
    (Size: 33.00KB, Downloaded 180 times)
Re: Overflowing table in fixed layout [message #1067107 is a reply to message #1066589] Fri, 05 July 2013 17:33 Go to previous message
I posted an example of one way you could do this in your other thread. I was able to continue the columns on the same page by using grouping and adding another table in the group footer.
Previous Topic:how to view source-code in a rptdocument
Next Topic:Problem with the export of a report with the Birt RE API
Current Time: Sun Jul 20 19:58:19 EDT 2025
Powered by FUDForum. Page generated in 0.03870 seconds
