| [ETL] same metamodel [message #1066851] |
Thu, 04 July 2013 14:43  |
I want to apply design pattern to UML classes.
In this situation, source and targed metamodels are the same (UML Metamodel).
when I tried to do this, I got an error.
I start with a simple example, but it didn't work.
Content of my etl file is:
pre{
"Running ETL".println();
var pk : new OO!Package;
post {
"Running Successful".println();
rule Class2Class
transform c : OO!Class
to t : OO!Class {
t.name = c.name;
t.package = pk;
and content of my launch file is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.epsilon.etl.eclipse.dt.launching.EtlLaunchConfigurationDelegate">
<booleanAttribute key="fine_grained_profiling" value="false"/>
<listAttribute key="models">
<listEntry value="#
#Thu Jul 04 01:13:16 GMT+03:30 2013
isMetamodelFileBased=false
name=OO
readOnLoad=true
storeOnDisposal=false
aliases=
cached=true
fileBasedMetamodelUri=platform\:/resource/org.eclipse.epsilon.examples.metamodels/OO.ecore
metamodelUri=OO
modelUri=platform\:/resource/OO2TargetOO/models/OOInstance.model
type=EMF
modelFile=/OO2TargetOO/models/OOInstance.model
expand=false
metamodelFile=org.eclipse.epsilon.examples.metamodels/OO.ecore
<listEntry value="#
#Thu Jul 04 22:20:49 GMT+03:30 2013
name=OO
readOnLoad=false
storeOnDisposal=true
aliases=
cached=true
fileBasedMetamodelUri=platform\:/resource/org.eclipse.epsilon.examples.metamodels/OO.emf
metamodelUri=OO
modelUri=platform\:/resource/OO2TargetOO/models/TargetOOInstance.model
type=EMF
modelFile=/OO2TargetOO/models/TargetOOInstance.model
expand=false
metamodelFile=/org.eclipse.epsilon.examples.metamodels/OO.emf
<listEntry value="#
#Thu Jun 04 21:54:41 BST 2009
name=Trace
readOnLoad=false
aliases=
metamodelUri=SimpleTrace
type=EMF
modelFile=/OO2TargetOO/models/Trace.model
expand=true
metamodelFile=
</listAttribute>
<booleanAttribute key="profile_model_loading" value="false"/>
<booleanAttribute key="profiling_enabled" value="false"/>
<booleanAttribute key="reset_profiler" value="false"/>
<stringAttribute key="source" value="/OO2TargetOO/OO2TargetOO.etl"/>
<stringAttribute key="sourceModel" value="OO"/>
<stringAttribute key="targetModel" value="OO"/>
<listAttribute key="tools"/>
<stringAttribute key="transformationStrategy" value="Default"/>
</launchConfiguration>
when I tried to run it, I got following error.
Internal error: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Content is not allowed in prolog.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load[XMLLoadImpl.java:195]
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad[XMLResourceImpl.java:240]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load[ResourceImpl.java:1505]
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load[ResourceImpl.java:1284]
at org.eclipse.epsilon.emc.emf.EmfUtil.register[EmfUtil.java:161]
at org.eclipse.epsilon.emc.emf.EmfModel.determinePackagesFrom[EmfModel.java:392]
at org.eclipse.epsilon.emc.emf.EmfModel.loadModelFromUri[EmfModel.java:235]
at org.eclipse.epsilon.emc.emf.EmfModel.loadModel[EmfModel.java:167]
at org.eclipse.epsilon.eol.models.CachedModel.load[CachedModel.java:147]
at org.eclipse.epsilon.emc.emf.EmfModel.load[EmfModel.java:151]
at org.eclipse.epsilon.eol.dt.launching.EclipseContextManager.loadModels[EclipseContextManager.java:141]
at org.eclipse.epsilon.eol.dt.launching.EclipseContextManager.setup[EclipseContextManager.java:83]
at org.eclipse.epsilon.eol.dt.launching.EpsilonLaunchConfigurationDelegate.launch[EpsilonLaunchConfigurationDelegate.java:72]
at org.eclipse.epsilon.eol.dt.launching.EpsilonLaunchConfigurationDelegate.launch[EpsilonLaunchConfigurationDelegate.java:56]
at org.eclipse.debug.internal.core.LaunchConfiguration.launch[LaunchConfiguration.java:855]
at org.eclipse.debug.internal.core.LaunchConfiguration.launch[LaunchConfiguration.java:704]
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch[DebugUIPlugin.java:1047]
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run[DebugUIPlugin.java:1251]
at org.eclipse.core.internal.jobs.Worker.run[Worker.java:53]
Caused by: org.xml.sax.SAXParseExceptionpublicId: platform:/resource/org.eclipse.epsilon.examples.metamodels/OO.emf; systemId: platform:/resource/org.eclipse.epsilon.examples.metamodels/OO.emf; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException[Unknown Source]
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError[Unknown Source]
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError[Unknown Source]
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError[Unknown Source]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next[Unknown Source]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next[Unknown Source]
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument[Unknown Source]
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse[Unknown Source]
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse[Unknown Source]
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse[Unknown Source]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse[Unknown Source]
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse[Unknown Source]
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load[XMLLoadImpl.java:175]
... 18 more
I've registered my OO.ecore package.
Is it possible to use same metamodel for source and target models?
as an another test,
when I create a new instance of OO.ecore and rename it to "DB" and use it as target
model, it works fine, but if I rename it to "TargetOO", it doesn't work!!!
(I've created DB.emf and DB.ecore and I've register it as for "TargetOO" )
FUDForum. Page generated in 0.03133 seconds
