Home » Language IDEs » Java Development Tools (JDT) » Eclipse crash after first run(at the install of Eclipse it work perfectly until I close and restart again...)
Eclipse crash after first run [message #1066345] Tue, 02 July 2013 04:59 Go to next message
I have been getting some problem with my Eclipse IDE when developping an Eclipse RCP and RAP application. (last Eclipse Kepler, on Windows 7 64bit)
I install the environment, load up my workspace, and work with it... And when I close the platform and restart it, it crashes with this error:
!SESSION 2013-07-02 10:55:09.388 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=1.7.0_05
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=fr_FR
Framework arguments:  -product org.eclipse.epp.package.rcp.product
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.rcp.product
!ENTRY org.eclipse.debug.ui 4 0 2013-07-02 10:55:11.192
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.debug.internal.ui.DebugUIPlugin.start() of bundle org.eclipse.debug.ui.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: Workbench has not been created yet.
	at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:92)
	at org.eclipse.debug.internal.ui.contextlaunching.LaunchingResourceManager.startup(LaunchingResourceManager.java:546)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.getLaunchingResourceManager(DebugUIPlugin.java:357)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.start(DebugUIPlugin.java:569)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	... 12 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-07-02 10:55:11.847
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTException: Invalid thread access
	at org.eclipse.swt.SWT.error(SWT.java:4361)
	at org.eclipse.swt.SWT.error(SWT.java:4276)
	at org.eclipse.swt.SWT.error(SWT.java:4247)
	at org.eclipse.swt.widgets.Display.error(Display.java:1258)
	at org.eclipse.swt.widgets.Display.checkDevice(Display.java:764)
	at org.eclipse.swt.widgets.Display.addListener(Display.java:626)
	at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.<init>(IDEWorkbenchAdvisor.java:176)
	at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.<init>(IDEWorkbenchAdvisor.java:184)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:125)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
The only way I can rework with Eclipse is by re-installing a fresh version of Eclipse.
So one parameter in one of the plugin make it crash but which one ???
The error seems to happen before the loading of the workspace, so it is linked to Eclipse parameters.
[Updated on: Tue, 02 July 2013 05:04] by Moderator
Re: Eclipse crash after first run [message #1066857 is a reply to message #1066345] Thu, 04 July 2013 15:15 Go to previous message
Similar to bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=398515 /
https://bugs.eclipse.org/bugs/show_bug.cgi?id=398776
However, those were verified in build M20130123-1200 and your log says build M20130204-1200.
Please try this with the latest Eclipse 4.3 (Kepler) build. And if reproducible, file a new bug report.
Previous Topic:Missing names in quick fixes suggestion popup
Next Topic:Customize JDT Debug view
Current Time: Sat Jul 26 11:56:00 EDT 2025
Powered by FUDForum. Page generated in 0.08562 seconds
