Home » Modeling » OCL » [CompleteOCL] getValue of property direction of FlowPort
[CompleteOCL] getValue of property direction of FlowPort [message #1066767] Thu, 04 July 2013 05:42 Go to next message
i´m trying to validate a UML-model with a completeOCL-file and i need to group all FlowPorts that are owned by one Class in order of their direction. Therefore i need to compare the value of the property "direction" with each other, but when i call
self.getValue(self.getAppliedStereotype('SysML::PortAndFlows::FlowPort'),'direction').oclIsUndefined()
i always get true as the result. But changing this code to
self.getValue(self.getAppliedStereotype('SysML::PortAndFlows::FlowPort'),'base_Port').oclIsUndefined()
or to any other name of a property of flowport, i get false as the result..
so what is so special about the property "direction"?
for the validation i´m using the CompleteOCLEObjectValidator in Kepler release.
so here is my ocl-file for testing the getValue-method:
import uml: 'http://www.eclipse.org/uml2/4.0.0/UML#/'
import 'http://www.eclipse.org/papyrus/0.7.0/SysML#/'
context uml::Port
inv test ('blub'):
let stereo: Stereotype = self.getAppliedStereotype('SysML::PortAndFlows::FlowPort')
in not stereo.oclIsUndefined() implies not self.getValue(stereo,'direction').oclIsUndefined()
and here is the initialization of my Validator:
		CompleteOCLEObjectValidator val = new TestValidator(UMLPackage.eINSTANCE,ocluri);
		EValidator.Registry.INSTANCE.put(UMLPackage.eINSTANCE,val);
		EValidator.Registry.INSTANCE.put(SysmlPackage.eINSTANCE,val);
		EValidator.Registry.INSTANCE.put(EcorePackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(BlocksPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(PortandflowsPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(ModelelementsPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(ConstraintsPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(ActivitiesPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(AllocationsPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(RequirementsPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(UsecasesPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(StatemachinesPackage.eINSTANCE, val);
		EValidator.Registry.INSTANCE.put(InteractionsPackage.eINSTANCE, val);
		Diagnostic diag = Diagnostician.INSTANCE.validate(m);
best regards,
Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1066773 is a reply to message #1066767] Thu, 04 July 2013 06:17 Go to previous messageGo to next message
HI
getValue() and getAppliedStereotype() are part of the Java API and so
they lose type information. In particular getValue() return an Object
that causes trouble when the return is a Collection.
CompleteOCLEObjectValidator tells me that you are using the new Pivot
support that allows modeled access to stereotypes.
Have you tried
self.extension_FlowPort.direction
Ed Willink
On 04/07/2013 10:42, Ba sti wrote:
> result..
> release.
> context uml::Port
> inv test ('blub'):
> val);
> val);
> val);
> best regards,
> Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1066832 is a reply to message #1066773] Thu, 04 July 2013 10:47 Go to previous messageGo to next message
hi,
thanks for your answer.
i´m not able to perform this extension-method at the moment..
the method seems to be not declared for uml::Port
what changes are necessary to be able to use this special pivot methods?
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1066833 is a reply to message #1066832] Thu, 04 July 2013 10:54 Go to previous messageGo to next message
The extension_ properties are declared whenever stereotypes exist. It
should just work.
Post a zipped project.
Ed Willink
On 04/07/2013 15:47, Ba sti wrote:
> hi,
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1067575 is a reply to message #1066833] Tue, 09 July 2013 07:59 Go to previous messageGo to next message
hi,
here is my zipped project with an example model and ocl-file
thanks for your help!
Basti
  • Attachment: example.zip
    (Size: 11.67KB, Downloaded 259 times)
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1067788 is a reply to message #1067575] Wed, 10 July 2013 11:02 Go to previous messageGo to next message
Thanks. extension_FlowPort doesn't work because the Ecore models in use
do not have the required stereotype applications.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412680 raised.
Thanks again. The evaluation of 'direction' is special, in that it
partially succeeds, but uses a Java enumeration that is statically types
as EJavaObject for which the type rediscovery code has a missing case
resulting in an UnsupportedOperationException.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412685 raised.
Ed Willink
On 09/07/2013 12:59, Ba sti wrote:
> hi,
> Regards,
> Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1243087 is a reply to message #1067788] Mon, 10 February 2014 08:54 Go to previous messageGo to next message
as I can see, one of theses bugs has been resolved so far. But for me it´s still not possible to access the value of this Property. I got the following Exception:
Exception in thread "main" org.eclipse.ocl.examples.domain.values.impl.InvalidValueException: Unknown enumeration out
	at org.eclipse.ocl.examples.library.executor.AbstractIdResolver.boxedValueOfEnumerator(AbstractIdResolver.java:372)
	at org.eclipse.ocl.examples.library.executor.AbstractIdResolver.boxedValueOf(AbstractIdResolver.java:308)
	at org.eclipse.ocl.examples.library.executor.AbstractIdResolver.boxedValueOf(AbstractIdResolver.java:325)
	at org.eclipse.ocl.examples.pivot.library.EInvokeOperation.getResultValue(EInvokeOperation.java:117)
	at org.eclipse.ocl.examples.pivot.library.EInvokeOperation.evaluate(EInvokeOperation.java:101)
	at org.eclipse.ocl.examples.domain.library.AbstractPolyOperation.evaluate(AbstractPolyOperation.java:39)
	at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:744)
	at org.eclipse.ocl.examples.pivot.internal.impl.OperationCallExpImpl.accept(OperationCallExpImpl.java:433)
	at org.eclipse.ocl.examples.pivot.evaluation.EvaluationVisitorImpl.visitOperationCallExp(EvaluationVisitorImpl.java:643)
	at org.eclipse.ocl.examples.pivot.utilities.QueryImpl.evaluate(QueryImpl.java:197)
	at Example.doWork(Example.java:103)
	at Example.main(Example.java:79)
I´m using Kepler 4.3.1 with the latest nightly build of the ocl part.
I have added a small example that represents my problem.
best Regards,
Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1243319 is a reply to message #1243087] Mon, 10 February 2014 15:52 Go to previous messageGo to next message
Your example project has numerous compilation errors.
Ed Willink
On 10/02/2014 13:54, Ba sti wrote:
> best Regards,
> Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1243603 is a reply to message #1243319] Tue, 11 February 2014 02:25 Go to previous messageGo to next message
hi,
several compilation errors?
I´m sorry, there are no erros in my workbench.
Could it be that these errors are some unresolved jar-files?
I´m using the newest jar-files for ocl stuff. Otherwise i have no idea what´s the problem.
Should I post this example again with the normal kepler 4.3.1 jars?
regards,
Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1243631 is a reply to message #1243603] Tue, 11 February 2014 03:16 Go to previous messageGo to next message
There is no MANIFEST.MF!
Ed Willink
On 11/02/2014 07:25, Ba sti wrote:
> hi,
> what´s the problem.
> regards,
> Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1243662 is a reply to message #1243631] Tue, 11 February 2014 04:17 Go to previous messageGo to next message
hi,
sorry, I didn´t know that it´s necessary to have a Manifest.mf for a java project.
The last time i posted an example, it had worked without it.
So I´ve added it now, but it includes only one line, so i don´t know if this is better.
If not please tell me what i should do.
regards,
Basti
edit---------
added generated Manifest.mf from export runnable jar
[Updated on: Tue, 11 February 2014 05:00] by Moderator
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1244486 is a reply to message #1243662] Wed, 12 February 2014 07:04 Go to previous messageGo to next message
An empty manifest doesn't help.
If you use a manifest for an Eclipse plugin, Eclipse computes the class
path automaticalkly, so that I don't have to correct the details in your
..classpath file.
The manifest just needs to specify
Require-Bundle: org.eclipse.papyrus.sysml,
org.eclipse.ocl.examples.xtext.oclstdlib,
org.eclipse.ocl.examples.xtext.completeocl,
org.eclipse.ocl.examples.xtext.oclinecore,
org.eclipse.emf.mapping.ecore2xml,
org.eclipse.uml2.uml.resources
and the .classpath shrinks to
<classpath>
<classpathentry kind="con"
path="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.6"/>
path="org.eclipse.pde.core.requiredPlugins"/>
<classpathentry kind="src" path="src"/>
<classpathentry kind="output" path="bin"/>
</classpath>
The problem is that
self.getValue(self.getAppliedStereotype('SysML::PortAndFlows::FlowPort'), 'direction')
uses SysML without ever actually using SysML until an Enumerator needs
processing. Enumerator are an over-optimized EMF feature, since they
have no container to identify their Enumeration, consequently converting
them to a rational world requires an index all enumerators in the world
approach, and the world does not include SysML.
A trivial solution might be to just have a dummy query that explicitly
uses a SysML class.
More sensible would be to use a typed navigation such as
However the SysML model seems to be resisting my attempts to load it, so
await a further reply.
Ed Willink
On 11/02/2014 09:17, Ba sti wrote:
> hi,
> regards,
> Basti
Re: [CompleteOCL] getValue of property direction of FlowPort [message #1244494 is a reply to message #1244486] Wed, 12 February 2014 07:19 Go to previous message
It's bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=411614.
I'll try and have a look next week.
Ed Willink
> so await a further reply.
Previous Topic:Imact Analyzer + Code Generation
Next Topic:ecore & ocl generated classes: ExceptionInInitializerError
Current Time: Tue Jul 22 23:59:16 EDT 2025
Powered by FUDForum. Page generated in 0.58236 seconds
