Home » Archived » Jubula » Extending Jubula to select tabbed properties in tabbed property pages(How do we publish extensions?)
Extending Jubula to select tabbed properties in tabbed property pages [message #1022600] Fri, 22 March 2013 04:05 Go to next message
we implemented an extension to select a tabbed property within tabbed property pages (http://www.eclipse.org/articles/Article-Tabbed-Properties/tabbed_properties_view.html). How do we publish such extensions to the new software?
Ciao,
Michi
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1022619 is a reply to message #1022600] Fri, 22 March 2013 04:51 Go to previous messageGo to next message
Just to clarify - is your question about deploying the extension so that your tests can use it (if so - the extension manual has details), or about contributing it to Jubula? If it's about contributing, then the way to go about it would be to put in an enhancement with a patch.
Alex
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1022692 is a reply to message #1022619] Fri, 22 March 2013 07:12 Go to previous messageGo to next message
The contribution to Jubula is meant.
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1062932 is a reply to message #1022692] Tue, 11 June 2013 09:04 Go to previous messageGo to next message
Hi Michi,
Could you please share the this extension?
Alex
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1065755 is a reply to message #1062932] Thu, 27 June 2013 07:49 Go to previous messageGo to next message
Yes, of course. The extension can be used since Jubula 2.0.0.
If you want to use the extension, you have to do the following:
Changes in Jubula Client
Copy the bundle com.bmw.jubula.extension.rcp.toolkit_2.0.2.201306261839.jar into the folder jubula/plugins of your jubula client
Add the bundle information in bundles.info under jubula/configuration/org.eclipse.equinox.simpleconfigurator as follows:
com.bmw.jubula.extension.rcp.toolkit,2.0.2.201306261839,plugins/com.bmw.jubula.extension.rcp.toolkit_2.0.2.201306261839.jar,4,false
Changes in AUT
Copy the fragment com.bmw.jubula.extension.rcp.rc_2.0.3.201306261839.jar into the plugins folder of your AUT
Add the plugin com.bmw.jubula.extension.rcp.rc to config.ini of your AUT.
Test configuration
To select tab by name:
Configure test step by selecting component type "Tabbed Property Component" and action "Select tab by tab-name" and enter "nn_nn_tbc" for component name.
To select tab by id:
Configure test step by selecting component type "Tabbed Property Component" and action "Select tab by tab-id" and enter "nn_nn_tbc" for component name.
Map the physical tabbed property section (TabbedPropertyList$ListElement) to your logical component.
And that's it.
Hope it was helpful.
Michi
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1066735 is a reply to message #1065755] Thu, 04 July 2013 03:21 Go to previous messageGo to next message
Thanks a lot, Michi!
That works fine.
Alex
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1085115 is a reply to message #1022600] Mon, 12 August 2013 09:24 Go to previous messageGo to next message
your extension sounds very helpfully to me. But I have one problem by using it. The AUTAgent reports the following mistakes:
"AUT:15:21:07.214 [main] ERROR o.e.j.r.c.AUTServerConfiguration - java.lang.ClassNotFoundException: org.eclipse.jubula.rc.swt.tester.TabbedPropertyTester"
"AUT:15:49:16.716 [Connection.ReaderThread:Socket[addr=ZEB-NB13-0140.zeb.de/10.1.112.130,port=53573,localport=53625]] ERROR o.e.j.r.c.c.AbstractCapTestCommand - component
'org.eclipse.ui.internal.views.properties.tabbed.view.TabbedPropertyList$ListElement' is not supported: implementation class 'org.eclipse.jubula.rc.swt.tester.TabbedPrope
rtyTester' not found"
I followed your description written above and don't know what is going wrong and why he can not find this class?
Can you help me?
Kind regards,
Philipp Wueller
[Updated on: Mon, 12 August 2013 10:01] by Moderator
Re: Extending Jubula to select tabbed properties in tabbed property pages [message #1096655 is a reply to message #1065755] Wed, 28 August 2013 13:31 Go to previous message
Can you share the project of your extension to use as a template? I'm having some problems building a Jubula extension for a custom component and it could be useful.
Previous Topic:Problem with Component Names
Next Topic:problem installing guidancer on an old indigo eclipse
Current Time: Sun Jul 20 22:23:00 EDT 2025
Powered by FUDForum. Page generated in 0.05187 seconds
