Home » Modeling » Papyrus » How to show labels on activity diagram control flows(Newbie question)
How to show labels on activity diagram control flows [message #1066714] Wed, 03 July 2013 20:27 Go to next message
How do I get a label to show on a control flow on a Papyrus activity diagram? I thought the text that I typed into the box when I created the flow, or the "Name" field of the property view would appear on the control flow, and all the tutorials show that appearing, but I can't get the label to appear at all. I've tried on multiple control flows, and I've tried moving things around to make sure the label isn't hidden under something. What am I missing?
Re: How to show labels on activity diagram control flows [message #1066817 is a reply to message #1066714] Thu, 04 July 2013 09:57 Go to previous messageGo to next message
the control flow names are hidden after the control flow has been created by default.
If you want to have it displayed for all control flows, you should set the papyrus preferences:
Window => preferences => Papyrus => diagrams => activity => control Flow
In this preference page, you can set the labels to be displayed by default (on a standard papyrus installation, this should be guard and stereotypes). If you select the "name" checkbox, all the new control flows will display the name label.
If this is for few Control Flows, you can use the context menu on them (right click on a control flow, Filters, Manage Connector labels). In the dialog that opens, you can select the set of labels you want to show for that particular selected connector.
Hope this helps
Rémi
Re: How to show labels on activity diagram control flows [message #1066841 is a reply to message #1066817] Thu, 04 July 2013 12:43 Go to previous message
That works, thanks. It worried me for a moment that it didn't seem to do anything, but then I noticed you said that it worked for new control flows, so I had to manually change my existing ones. All working now! Smile
Previous Topic:Overriding Stereotype's properties and assigning them a value
Next Topic:Partition in Activity Diagram
Current Time: Wed Jul 23 05:41:54 EDT 2025
Powered by FUDForum. Page generated in 0.41032 seconds
