Home » Eclipse Projects » EclipseLink » Nulling an embedded object does not affect the database upon merge
Nulling an embedded object does not affect the database upon merge [message #1038948] Thu, 11 April 2013 10:38 Go to next message
I have the following classes:
@Entity
public class Reminder {
  private Location location;
  // other fields and methods
and
@Embeddable
public class Location {
  private double latitude;
  private double longitude;
  // no other fields here, just getters and setters
My database has a table REMINDER with columns LATITUDE and LONGITUDE to store the embedded field.
If I call someReminder.setLocation(someLocation), followed by em.merge(someReminder), the LATITUDE and LONGITUDE columns are filled in as expected. However, if I call someReminder.setLocation(null), followed by em.merge(someReminder), the LATITUDE and LONGITUDE columns are unchanged. Re-reading someReminder from the database gives back the previously stored location.
I am running on GlassFish 3.1.2.2 with EclipseLink 2.3.2.
And now for the strangest part:
If I run the exact same code on Java SE (with a different EntityManager and different transactions ofcourse, but using the same EclipseLink 2.3.2), I do get the expected results: the merge causes the columns LATITUDE and LONGITUDE to be nulled out.
Why isn't this working on Java EE ?
Re: Nulling an embedded object does not affect the database upon merge [message #1039904 is a reply to message #1038948] Fri, 12 April 2013 15:38 Go to previous messageGo to next message
Sounds like weaving might be a factor, assuming you didn't set up a java agent in the Java SE test as described here http://wiki.eclipse.org/EclipseLink/FAQ/JPA#How_to_disable_or_enable_weaving.3F
Weaving allows the use of attribute change tracking, which might be the cause of the issue, though I am just guessing. This can be tested directly by changing the weaving settings here:
http://wiki.eclipse.org/EclipseLink/UserGuide/JPA/Advanced_JPA_Development/Performance/Weaving/Disabling_Weaving_with_Persistence_Unit_Properties
If you can reproduce this outside of glassfish, try using the latest EclipseLink version to see if its been fixed, and file a bug to have it resolved.
If that doesn't help track it down, try using a find followed by a refresh on the someReminder in the EntityManager before the merge with logging enabled.
Best Regards,
Chris
Re: Nulling an embedded object does not affect the database upon merge [message #1040442 is a reply to message #1039904] Sat, 13 April 2013 11:45 Go to previous messageGo to next message
Hi Chris,
Thanks for the tip. Turning off weaving solved the problem. Would you recommend I turn it off all the time ?
Re: Nulling an embedded object does not affect the database upon merge [message #1065935 is a reply to message #1040442] Fri, 28 June 2013 07:54 Go to previous messageGo to next message
we have got a similar problem - disabled weaving solves the problem.
But what is the recommended way, enabled or disabled weaving?
Reiner
Re: Nulling an embedded object does not affect the database upon merge [message #1066637 is a reply to message #1065935] Wed, 03 July 2013 10:08 Go to previous message
Enabled weaving is recommend. Please log a bug for the issue (if it still occurs on 2.5), also ensure you don't have side-affects in your get/set methods that could be causing the issue.
Previous Topic:missing Embeddable
Next Topic:JPQL Question - empty string
Current Time: Sun Jul 27 03:28:32 EDT 2025
Powered by FUDForum. Page generated in 0.05352 seconds
