Home » Eclipse Projects » Remote Application Platform (RAP) » Need example to deploy a RAP 2.1 app on Tomcat server(Need a complete example to deploy a new RAP 2.1 application on a Tomcat server)
Need example to deploy a RAP 2.1 app on Tomcat server [message #1066617] Wed, 03 July 2013 09:13 Go to next message
Hi all,
I need an example of a RAP project to deploy on a tomcat server.
I would like work with the new target RAP 2.1 (official release) with a new Eclipse Kepler 4.3 (June 2013)
My Environment
Java JVM 7
Eclipse Kepler 4.3
WindowBuilderPro (for RWT: SWT Designer from http://download.eclipse.org/windowbuilder/WB/release/R201306261200/4.3/)
War Product Plugin last version (0.3.0.201305311343 from http://download.eclipse.org/releases/kepler)
My available servers
Tomcat 5.5.17
Tomcat 6.0.32
Tomcat 7.0.10
Tomcat 7.0.39
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1066618 is a reply to message #1066617] Wed, 03 July 2013 09:17 Go to previous messageGo to next message
Today, I know how to create a new RAP project with the RAP target 2.1 (release of June 2013)
I can start my new project with Jetty into my Eclipse Kepler environment
I cannot start my product (war) with a Tomcat server (local Windows desktop)
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1066623 is a reply to message #1066617] Wed, 03 July 2013 09:32 Go to previous messageGo to next message
In the attachment file, you'll find two projects:
- MyApp (Rap 2.1 Project - the main application)
- MyCommon (a plugin with the future common RAP features for the current "MyApp" and the future other RAP applications)
Note: MyApp is just a Hello World application... (to reduce the size of the project)
To run this application into Eclipse Kepler;
You must right-click on the MyApp project and "Run As > RAP application"
The entry point of my application is the following path:
http://127.0.0.1:52772/myapp
Note about the port: it's a generated port by eclipse (but you can fix it into the launching file)
The launching configuration is described into the "MyApp.launch" file
The war product to create a new war is the "mywar.warproduct" file
I know how create, deploy and use a war file (RAP 1.5.X) on tomcat
create => war product plugin
deploy => start the tomcat server
use => call the URL of my application
For example in RAP 1.5.X with a custom theme (id: customTheme), the url was
http://127.0.0.1:52772/myapp/customTheme
Now: how to run a "correct" war file (RAP 2.1) on a tomcat server?
I don't know.
Please, Help me
Thanks in advance
  • Attachment: ng.zip
    (Size: 50.53KB, Downloaded 262 times)
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1066962 is a reply to message #1066623] Fri, 05 July 2013 05:00 Go to previous messageGo to next message
you didn't explain the problem so far. Didn't you manage to export a war
file? Did you export a war but it didn't work?
In case you re-used an existing war products file from an earlier
version, you could try to delete it and create a new one from a working
launch config.
Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067019 is a reply to message #1066962] Fri, 05 July 2013 09:08 Go to previous messageGo to next message
I can create a war file with the "War Product Plugin"
But I cannot use this war with a tomcat server because, the response of this server is always: 404
Example with a Tomcat 5.5.17
1/ After creation of the war file "mywar.war" (Eclipse > War Product > config > Wizard to create a new war)
2/ I deploy the war file on my tomcat server (local desktop)
3/ I got a new "mywar" folder in my tomcat server (C:\...\apache-tomcat-5.5.17\webapps)
4/ I call my application with the following URL:
http://127.0.0.1/mywar
5/ The response is:
HTTP Status 404 - ProxyServlet: /mywar
type Status report
message ProxyServlet: /mywar
description The requested resource (ProxyServlet: /mywar) is not available.
Apache Tomcat/5.5.17
Note: into Eclipse with Jetty,
http://127.0.0.1/mywar shows my application!?
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067020 is a reply to message #1066617] Fri, 05 July 2013 09:11 Go to previous messageGo to next message
5/ The response is:
type Status report
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067025 is a reply to message #1066617] Fri, 05 July 2013 09:24 Go to previous messageGo to next message
Simple question:
How to call my application after deployment?
http://localhost/MyApp doesn't work
if "localhost" is a Tomcat Server
I receive an error "404"
http://localhost/MyApp works
if "localhost" is the Jetty Server (from my Eclipse Kelper Environment)
I see my application...
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067063 is a reply to message #1067025] Fri, 05 July 2013 11:54 Go to previous messageGo to next message
In a tomcat deployment, every web application has a context path. If
your war file is named 'foo.war', the context path should be 'foo/'. So
instead of http://localhost/MyApp, you have to use the URL
http://localhost/foo/MyApp.
HTH,
Ralf
Ralf Sternberg
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067270 is a reply to message #1067063] Mon, 08 July 2013 03:35 Go to previous messageGo to next message
Ralf Sternberg wrote on Fri, 05 July 2013 11:54
HTH,
Ralf
Ralf Sternberg
Ok - I know that but I don't understand why the response of my server is always:
HTTP Status 404 - /mywar/myapp
I tried with others names of war file (for other paths) and I got always the same response:
HTTP Status 404 - /XXXXXX/myapp
XXXXXX for other paths (wars file names)
Thank you anyway for the time you spend here
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067274 is a reply to message #1067270] Mon, 08 July 2013 03:52 Go to previous messageGo to next message
Hi Francis,
please ensure that all the bundles are in active state after deployment.
To do so, enable OSGi console in web.xml (remove the comment from
console command line parameter) and use "ss" command to list your
bundles. Post the output of the command here.
Best,
Ivan
>> So instead of http://localhost/MyApp, you have to use the URL
>> HTH,
>> Ralf
>> Ralf Sternberg
>> Blog: http://eclipsesource.com/blogs/
>> Professional services for RAP and RCP?
>> http://eclipsesource.com/services/rap/
> is always:
Ivan Furnadjiev
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067357 is a reply to message #1066617] Mon, 08 July 2013 08:02 Go to previous messageGo to next message
Ok, I found the problem.
New rap target 2.1 is not compatible with Tomcat 5.5.17
With a 6.0.32, the product works fine.
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067361 is a reply to message #1066617] Mon, 08 July 2013 08:08 Go to previous messageGo to next message
I've modified "mywar.warproduct" like that:
<?pde version="3.5"?>
<product useFeatures="false" includeLaunchers="false">
   <plugins>
      <plugin id="javax.xml"/>
      <plugin id="myApp"/>
      <plugin id="myCommon"/>
      <plugin id="org.apache.felix.gogo.command"/>
      <plugin id="org.apache.felix.gogo.runtime"/>
      <plugin id="org.apache.felix.gogo.shell"/>
      <plugin id="org.eclipse.core.commands"/>
      <plugin id="org.eclipse.core.contenttype"/>
      <plugin id="org.eclipse.core.jobs"/>
      <plugin id="org.eclipse.core.runtime"/>
      <plugin id="org.eclipse.equinox.app"/>
      <plugin id="org.eclipse.equinox.common"/>
      <plugin id="org.eclipse.equinox.console"/>
      <plugin id="org.eclipse.equinox.ds"/>
      <plugin id="org.eclipse.equinox.http.registry"/>
      <plugin id="org.eclipse.equinox.http.servlet"/>
      <plugin id="org.eclipse.equinox.http.servletbridge"/>
      <plugin id="org.eclipse.equinox.preferences"/>
      <plugin id="org.eclipse.equinox.registry"/>
      <plugin id="org.eclipse.equinox.servletbridge"/>
      <plugin id="org.eclipse.equinox.util"/>
      <plugin id="org.eclipse.osgi"/>
      <plugin id="org.eclipse.osgi.services"/>
      <plugin id="org.eclipse.rap.jface"/>
      <plugin id="org.eclipse.rap.rwt"/>
      <plugin id="org.eclipse.rap.rwt.osgi"/>
   </plugins>
   <configurations>
      <plugin id="javax.xml" autoStart="true" startLevel="0" />
      <plugin id="myApp" autoStart="true" startLevel="0" />
      <plugin id="myCommon" autoStart="true" startLevel="0" />
      <plugin id="org.apache.felix.gogo.command" autoStart="true" startLevel="0" />
      <plugin id="org.apache.felix.gogo.runtime" autoStart="true" startLevel="0" />
      <plugin id="org.apache.felix.gogo.shell" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.commands" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.contenttype" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.jobs" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.app" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.console" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.ds" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.http.registry" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.http.servlet" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.http.servletbridge" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.preferences" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.registry" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.servletbridge" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.equinox.util" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.osgi" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.osgi.services" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.jface" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.rwt" autoStart="true" startLevel="0" />
      <plugin id="org.eclipse.rap.rwt.osgi" autoStart="true" startLevel="0" />
   </configurations>
   <warConfiguration webXml="/MyApp/WEB-INF/web.xml" launchIni="/MyApp/WEB-INF/launch.ini">
   <libraries>
      <library path="org.eclipse.equinox.servletbridge_1.2.300.v20130508-1243.jar" fromTarget="true"/>
   </libraries>
   </warConfiguration>
</product>
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067399 is a reply to message #1067357] Mon, 08 July 2013 10:08 Go to previous messageGo to next message
Francis,
are you using the RAP 2.1 release? There was a problem with RC2 related
to the fix for bug:
408656: HttpOnly flag for settingStore cookie
https://bugs.eclipse.org/bugs/show_bug.cgi?id=408656
We reverted this fix in RC3+ in order to keep compatibility with servlet
2.5 (Tomcat 5.5.17). With RAP 2.1 release your application should work
fine with Tomcat 5.5.17.
Best,
Ivan
Ivan Furnadjiev
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067497 is a reply to message #1067357] Tue, 09 July 2013 02:17 Go to previous messageGo to next message
Our demos running on a Tomcat 5.5.20. So that can't be the problem.
Ralf
Ralf Sternberg
Re: Need example to deploy a RAP 2.1 app on Tomcat server [message #1067520 is a reply to message #1067399] Tue, 09 July 2013 04:24 Go to previous message
Ivan Furnadjiev wrote on Mon, 08 July 2013 10:08
Francis,
to the fix for bug:
Best,
Ivan
Ivan Furnadjiev
Yes, I use the official release of RAP Target
2.1 Release
based on Eclipse 4.3
Published: June 26, 2013
From the Software site: http://download.eclipse.org/rt/rap/2.1
If you want test it, you can download my project (see the third post in the current topic)
Previous Topic:column pack on virtual table
Next Topic:In a MARKUP_ENABLED table, clicking on the link with img tag in a tag will not trigger an SWT.Select
Current Time: Sat Jul 26 02:48:03 EDT 2025
Powered by FUDForum. Page generated in 0.07218 seconds
