Home » Eclipse Projects » Equinox » Problem with WeavingHook starting too late
Problem with WeavingHook starting too late [message #1066011] Fri, 28 June 2013 16:45 Go to next message
I am using Eclipse 4.3 and ObjectWeb ASM in a plugin to add some low level instrumentation to "org.eclipse.swt.widgets.Display".
When I launch the Eclipse workbench as an Eclipse application, the plugin works correctly: my WeavingHook method is called with classes as they are being loaded, beginning shortly before the loading of Display.class.
The problem is, after my plugin has been installed using P2, the calls to WeavingHook start after Display.class has already been loaded.
My weavinghook.xml specifies enabled="true" immediate="true"
I have set the plugin to be "unpacked" after installation with P2.
Is there a way to ensure that my weaving hook is activated before a specific class or bundle is loaded?
Any idea of what is causing the problem?
Thanks...
Re: Problem with WeavingHook starting too late [message #1066023 is a reply to message #1066011] Fri, 28 June 2013 23:43 Go to previous messageGo to next message
You will probably need to use start levels to make sure your weaving hook bundle is started before other bundles which load classes you want to weave.
Re: Problem with WeavingHook starting too late [message #1066080 is a reply to message #1066023] Sat, 29 June 2013 23:50 Go to previous messageGo to next message
Thanks for the pointer.
Is there a way to specify a start level for an "ordinary" plugin? That is, I am not building an RCP or other product. All of the reference uses of start level that I have found by Googling are specific to product builds.
Re: Problem with WeavingHook starting too late [message #1066447 is a reply to message #1066023] Tue, 02 July 2013 13:01 Go to previous messageGo to next message
Guessing a bit, but without a clear success -- that is, I cannot tell if it is being recognized or is in someway not correct/sufficient to change the start level. Here is my p2.inf file, as stored in the MANIFEST.MF directory of my weaving plugin.
#create a requirement on the fragment we are creating
requires.0.namespace=org.eclipse.equinox.p2.iu
requires.0.name=configure.net.certiv.bent.core
requires.0.greedy=true
#create a IU fragment named configure.net.certiv.bent.core
units.0.id=configure.net.certiv.bent.core
units.0.provides.1.namespace=org.eclipse.equinox.p2.iu
units.0.provides.1.name=configure.net.certiv.bent.core
units.0.instructions.install=org.eclipse.equinox.p2.touchpoint.eclipse.installBundle(bundle:${artifact});
units.0.instructions.uninstall=org.eclipse.equinox.p2.touchpoint.eclipse.uninstallBundle(bundle:${artifact});
units.0.instructions.unconfigure=org.eclipse.equinox.p2.touchpoint.eclipse.setStartLevel(startLevel:-1); org.eclipse.equinox.p2.touchpoint.eclipse.markStarted(started:false);
units.0.instructions.configure=org.eclipse.equinox.p2.touchpoint.eclipse.setStartLevel(startLevel:1);org.eclipse.equinox.p2.touchpoint.eclipse.markStarted(started:true);
# add multiple sets of host requirements to ensure this p2.inf is selected
units.0.hostRequirements.1.namespace=osgi.bundle
units.0.hostRequirements.1.name=net.certiv.bent.core
units.0.hostRequirements.1.greedy=false
units.0.hostRequirements.2.namespace=org.eclipse.equinox.p2.eclipse.type
units.0.hostRequirements.2.name=bundle
units.0.hostRequirements.2.range=[1.0.0,2.0.0)
units.0.hostRequirements.2.greedy=false
units.0.requires.1.namespace=osgi.bundle
units.0.requires.1.name=net.certiv.bent.core
units.0.requires.1.greedy=false
Any suggestions as to what to change or try next would be appreciated.
Thanks...
Re: Problem with WeavingHook starting too late [message #1066448 is a reply to message #1066447] Tue, 02 July 2013 13:02 Go to previous message
Should say, META-INF directory.
Previous Topic:Add maven NAR files to Target Platform
Next Topic:p2 installation question
Current Time: Sat Jul 26 23:39:19 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
