Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [ECP][CDO] connect to cdo repository without branching support
[ECP][CDO] connect to cdo repository without branching support [message #1066385] Tue, 02 July 2013 08:01 Go to next message
Hi all
I am getting the following exception when connecting to a remote CDO repository in the EMFClient:
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.loadSubBranches(HibernateStoreAccessor.java:439)
at org.eclipse.emf.cdo.internal.server.Repository.loadSubBranches(Repository.java:412)
at org.eclipse.emf.cdo.internal.common.branch.CDOBranchImpl.getBranches(CDOBranchImpl.java:175)
at org.eclipse.emf.cdo.internal.common.branch.CDOBranchImpl.getBranches(CDOBranchImpl.java:189)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadSubBranchesIndication.responding(LoadSubBranchesIndication.java:45)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:134)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)
We are using the hibernate store which does not support branching. Is it possible to connect without branching?
Thanks!
Re: [ECP][CDO] connect to cdo repository without branching support [message #1066392 is a reply to message #1066385] Tue, 02 July 2013 08:13 Go to previous messageGo to next message
BTW: branching is turned off in the server config:
<property name="supportingBranches" value="false"/>
Re: [ECP][CDO] connect to cdo repository without branching support [message #1066417 is a reply to message #1066385] Tue, 02 July 2013 10:57 Go to previous messageGo to next message
Am 02.07.2013 14:01, schrieb Erdal Karaca:
> Hi all
> at
> at
This could be a pure UI issue but I'm not sure. If the CDO repo is configured without branching support the ECP UI
should not try to request sub branches of the MAIN branch. I could also imagine to relax the CDO server such that it
returns an empty collection instead of throwing an exception. I leave it to you where you report a bugzilla ;-)
Cheers
/Eike
http://www.esc-net.de
Re: [ECP][CDO] connect to cdo repository without branching support [message #1066418 is a reply to message #1066417] Tue, 02 July 2013 11:04 Go to previous messageGo to next message
I did exactly that and got no more exceptions, but I still cannot "browse" the repository: UI has no option to create a new CDO project (I can only create a new empty project and select an existing xmi file).
Eike Stepper wrote on Tue, 02 July 2013 16:57
Re: [ECP][CDO] connect to cdo repository without branching support [message #1066481 is a reply to message #1066418] Tue, 02 July 2013 15:51 Go to previous messageGo to next message
do you mean, the CDO Repository node in the repository browser has no
children? It is intended to select one of these and check them out as
projects.
The UI of the CDO provider currently does not allow to create projects
in the model explorer, which are not connected to any repository. The
other option you are refering to is provided by the file provider.
Jonas
Am 02.07.2013 17:04, schrieb Erdal Karaca:
>> I could also imagine to relax the CDO server such that it returns an
Re: [ECP][CDO] connect to cdo repository without branching support [message #1066895 is a reply to message #1066481] Fri, 05 July 2013 01:45 Go to previous messageGo to next message
Am 02.07.2013 21:51, schrieb Jonas Helming:
> do you mean, the CDO Repository node in the repository browser has no children? It is intended to select one of these
> and check them out as projects.
> The UI of the CDO provider currently does not allow to create projects in the model explorer, which are not connected
> to any repository.
I tried it out yesterday and I can confirm: There is no Checkout action anymore on the branches that are displayed
inside the CDO repo. I checked the sources (and the Git history) for quite some while but couldn't figure out how/when
something changed that caused this. I'm pretty sure that I didn't touch ECP or its CDO provider for more than a year, so
someone else must have caused this regression.
I checked that CDOBranchWrapper properly implements ECPCheckoutSource and that there's a command handler contributed in
the framework's plugin.xml. Where else should I look? How can I debug why that contribution does not lead to a visible
action in the popup menu?
Cheers
/Eike
> The other option you are refering to is provided by the file provider.
> Regards
> Jonas
Re: [ECP][CDO] connect to cdo repository without branching support [message #1066948 is a reply to message #1066895] Fri, 05 July 2013 04:38 Go to previous messageGo to next message
I just checked, I have a check-out action either in latest develop state
and in 1.0.0. I did not check the functionality, though.
Can you describe where you tested this?
Jonas
Am 05.07.2013 07:45, schrieb Eike Stepper:
>> Hi,
>> projects.
> anymore on the branches that are displayed inside the CDO repo. I
> couldn't figure out how/when something changed that caused this. I'm
> year, so someone else must have caused this regression.
> and that there's a command handler contributed in the framework's
> contribution does not lead to a visible action in the popup menu?
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Regards
>> Jonas
Re: [ECP][CDO] connect to cdo repository without branching support [message #1067824 is a reply to message #1066418] Wed, 10 July 2013 13:25 Go to previous messageGo to next message
Hi Erdal,
is this still open?
Could you create a BR for that?
Cheers
Jonas
Re: [ECP][CDO] connect to cdo repository without branching support [message #1067835 is a reply to message #1067824] Wed, 10 July 2013 15:20 Go to previous message
Hi Jonas,
This is still unresolved:
412705: [CDO] Cannot checkout MAIN branch
https://bugs.eclipse.org/bugs/show_bug.cgi?id=412705
The intention is to include the ECP Perspective in an existing Eclipse RCP application which uses CDO.
Previous Topic:[EMF Store] External Editor
Next Topic:Java code from Ecore
Current Time: Wed Jul 23 04:53:41 EDT 2025
Powered by FUDForum. Page generated in 0.33813 seconds
