Home » Modeling » Compare » EMF Compare get Object Attributes
EMF Compare get Object Attributes [message #1062893] Tue, 11 June 2013 05:27 Go to next message
Hi there.
I've been working on my project with EMF Compare and for my purpose I need to get the name of the Object where there is a difference between two textual models.
I'd really appreciate any help from you.
Regards.
[Updated on: Thu, 13 June 2013 13:28] by Moderator
Re: EMF Compare get Object Attributes [message #1063429 is a reply to message #1062893] Thu, 13 June 2013 03:25 Go to previous messageGo to next message
I have no idea what you're trying to achieve, but I guess what you want is to retrieve info about the target of a diff. With EMF Compare 1, you will have to cast to the proper diff type (ModelElementChangeRightTarget, ModelElementChangeLeftTarget, ...), use the getter for the target element (getRightElement, getLeftElement, ...) and navigate from that element to the info you seek : getClass(), getName(), etc.
You should switch to EMF Compare 2, since exploiting the comparison result is much easier now :
IComparisonScope scope = EMFCompare.createDefaultScope(resourceSet1, resourceSet2);
Comparison comparison = EMFCompare.builder().build().compare(scope);
List<Diff> differences = comparison.getDifferences();
for (Diff diff : differences) {
	if (diff instanceof ReferenceChange) {
		EObject changed = ((ReferenceChange)diff).getValue();
		System.out.println("Changed EObject '" + changed.getName() + "' of type : " + changed.getClass());
Laurent Goubet
Obeo
Re: EMF Compare get Object Attributes [message #1066102 is a reply to message #1063429] Sun, 30 June 2013 12:54 Go to previous messageGo to next message
Hi guys.
I also have some question about this topic. In my case I need to get the 2 objects where there was a change on different attributes. But until now everything seems to be workless.
[Updated on: Thu, 18 July 2013 11:48] by Moderator
Re: EMF Compare get Object Attributes [message #1066353 is a reply to message #1066102] Tue, 02 July 2013 05:35 Go to previous messageGo to next message
Hans,
You may want to look at a few java tutorials before trying to tackle Eclipse plugin development.
What you have here is a very basic exception, which tells you (straight from the documentation of "ClassCastException") :
Thrown to indicate that the code has attempted to cast an object to a subclass of which it is not an instance. For example, the following code generates a ClassCastException:
Object x = new Integer(0);
System.out.println((String)x);
In this case, you are trying to cast a reference order changed as an UpdateAttribute, while "UpdateAttribute" has no relation to a ReferenceChange whatsoever.
Laurent Goubet
Obeo
Re: EMF Compare get Object Attributes [message #1070761 is a reply to message #1066353] Thu, 18 July 2013 11:54 Go to previous messageGo to next message
Laurent thanks a lot for your replay and explanation, actually I feel a little embarrassed...
Re: EMF Compare get Object Attributes [message #1809782 is a reply to message #1070761] Tue, 23 July 2019 07:56 Go to previous messageGo to next message
Hi Guys,
Thanks for the above post and replies.
I am also working on similar project where i want the differences between two run-time generated files (mydsl files). The two files are :
1) the current run-time file where user will do the updates and
2) locally stored file (without these latest user changes i.e. consider last git commit file)
I am able to get the differences with Diff of EMF Compare. I also got the EObject using above code snippet but I am not yet able to get the values.
Now I want to fetch the differences in terms of EMF model classes with the changed values or want to access that EObject.
How it could be done?
Re: EMF Compare get Object Attributes [message #1809792 is a reply to message #1070761] Tue, 23 July 2019 09:20 Go to previous messageGo to next message
Hi Guys,
Re: EMF Compare get Object Attributes [message #1810010 is a reply to message #1809792] Mon, 29 July 2019 03:30 Go to previous message
Please create a new thread for new questions, don't resurect old ones.
You might want to look at what we're doing in org.eclipse.emf.compare.utils.EMFComparePrettyPrinter to navigate the differences and look at the documentation for the core concepts. Though incomplete, the documentation could explain what most references mean on the Diff objects. If this is not enough, please detail your questions (in a new thread).
Laurent Goubet
Obeo
Previous Topic:Package with uri 'http:///org/eclipse/epf/uma/resourcemanager.ecore' not found
Next Topic:Custom Comparison
Current Time: Tue Sep 16 02:10:48 EDT 2025
Powered by FUDForum. Page generated in 0.05303 seconds
