Invalid BPMN2 from the modeler? [message #1066339] |
Tue, 02 July 2013 04:51  |
On creating a BPMN 2 Choreography Diagram and adding a message and an item deifnition by using a wsdl, the following BPMN 2 file is generated: ttp://pastebin.com/YUQeFPG5
<bpmn2:interface id="Interface_1" implementationRef="ttp://www.webservicex.net/RealTimeMarketData.asmx?WSDL#//@ePortTypes.0" name="RealTimeMarketDataSoap">
The implementationRef is supposed to be a QName, and if I deserialize it with a JAXB, I get a null implementationRef. Is this is a bug? I want to associate a choreography partner with an Interface, and the interface to a WSDL, while keeping true to the BPMN 2 syntax and semantic. How do I do that?
These are the loaded plugins from org.eclipse.bpmn2 namespace
org.eclipse.bpmn2 (0.7.0.201304230617) "BPMN2 Model" [Active]
org.eclipse.bpmn2.edit (0.7.0.201304230617) "BPMN2 Edit Support" [Active]
org.eclipse.bpmn2.editor (0.7.0.201304230617) "BPMN2 Editor" [Active]
org.eclipse.bpmn2.modeler.core (0.2.5.201305082126) "BPMN2 Editor Core" [Active]
org.eclipse.bpmn2.modeler.runtime.example (0.2.5.201305082126) "Example Runtime Plugin" [Active]
org.eclipse.bpmn2.modeler.runtime.jboss.jbpm5 (0.2.5.201305082126) "BPMN2 Editor Runtime extensions for JBoss jBPM5" [Active]
org.eclipse.bpmn2.modeler.ui (0.2.5.201305082126) "BPMN2 Editor UI" [Active]
org.eclipse.bpmn2.modeler.wsil (0.2.5.201305082126) "WSIL Support for BPMN2 Modeler" [Active]
[Updated on: Tue, 02 July 2013 04:58] by Moderator
FUDForum. Page generated in 0.04715 seconds
