Home » Archived » Jubula » Date Widget and others not supported as GRC?
Date Widget and others not supported as GRC? [message #1066256] Mon, 01 July 2013 13:52 Go to next message
I have posted this bug a while ago on the GUIdancer forum. The DateWidget and others had some
basic support in the past GUIdancer releases. In the 7.x release, object mapping is still working but simple
test cases like click into GRC will fail with a configuration error.
Is the fix for this problem in the actual GUIdancer/Jubula release or will it come in the future?
Re: Date Widget and others not supported as GRC? [message #1066320 is a reply to message #1066256] Tue, 02 July 2013 03:40 Go to previous messageGo to next message
I've encountered this issue too. Object mapping of date widget works fine, but clickInComponent and clickLeft_single fail with a configuration error.
Jubula version 2.0.0
Windows Vista Business 32-bit
RCP AUT
Cheers
Re: Date Widget and others not supported as GRC? [message #1066556 is a reply to message #1066320] Wed, 03 July 2013 03:31 Go to previous messageGo to next message
The bug was fixed for the 7.1 release. If there are remaining issues, please reopen the ticket.
HTH,
Alex
Re: Date Widget and others not supported as GRC? [message #1066715 is a reply to message #1066556] Wed, 03 July 2013 22:14 Go to previous messageGo to next message
Thanks for the update. I've upgraded to Jubula 7.1 but unfortunately the issue still occurs.
Steps I took:
1) Export project from Jubula 2.0.
2) Install Jubula 7.1 standalone full version: Windows 32-bit installer.
3) Import project into Jubula 7.1.
4) Run very basic test (checking AUT version number, just a menu selection and a label text comparison) to ensure it's working. Success.
5) Make new Object Mapping of a date widget in the AUT. Widget maps as a Graphics Component.
6) Make new minimal test case to click (ub_grc_clickLeft_single) in date widget.
7) Run test case; fails with Configuration Error.
Is there a fault with my method? If not let me know and I'll reopen the ticket.
Mike
Jubula standalone 7.1.0
Java 1.7.0_21
RCP AUT
Re: Date Widget and others not supported as GRC? [message #1067268 is a reply to message #1066715] Mon, 08 July 2013 03:28 Go to previous messageGo to next message
Hi Mike,
It sounds like something may have not been correctly migrated. Did you follow all the migration steps from the installation manual when you updated to Jubula 2.0?
Alex
Re: Date Widget and others not supported as GRC? [message #1067489 is a reply to message #1067268] Tue, 09 July 2013 01:04 Go to previous message
Hi Alex,
You're correct, it was a migration issue. I had not updated the RCP remote control plugin org.eclipse.jubula.rc.rcp_$VERSION.jar from the Jubula 2.0 to the Jubula 7.1 version. Working fine now.
Mike
Previous Topic:Jubula vs SWTBot
Next Topic:How to make sure "Move to External Project" does not break Test Cases?
Current Time: Sat Jul 26 11:38:58 EDT 2025
Powered by FUDForum. Page generated in 0.05253 seconds
