Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Adding menu to swt table(Adding same menu to multiple SWT tables)
Adding menu to swt table [message #1066207] Mon, 01 July 2013 10:41 Go to next message
I want to add same menu on multiple tables(SWT table). When user clicks on menu items, I want to detect the table associated with that menu. See the code below.
private void setMenu(Table table) {
        Listener popUpListener = new Listener() {
            public void handleEvent(Event event) {
                MenuItem item = (MenuItem)event.widget;
                Menu pare = item.getParent();
                Decorations fdf = pare.getParent();
                                    //Code to get table name or instance of table.
        Menu menu = new Menu(table); // where table1 is your table
        MenuItem item1 = new MenuItem(menu, SWT.PUSH);
        item1.setText("Copy cell");
        item1.addListener(SWT.Selection, popUpListener);
        MenuItem item2 = new MenuItem(menu, SWT.PUSH);
        item2.setText("Copy row");
        item2.addListener(SWT.Selection, popUpListener);
        MenuItem item3 = new MenuItem(menu, SWT.PUSH);
        item3.setText("Copy column");
        item3.addListener(SWT.Selection, popUpListener);
        MenuItem item4 = new MenuItem(menu, SWT.PUSH);
        item4.setText("Copy all");
        item4.addListener(SWT.Selection, popUpListener);
        table.setMenu(menu);
setMenu method is called multiple times sending the instances of table. How I can detect the table associated with the currently popped up menu in pop-up listener.
Re: Adding menu to swt table [message #1066244 is a reply to message #1066207] Mon, 01 July 2013 13:12 Go to previous messageGo to next message
note sure if that is the currect way. but, try to add shownMenu listener
for each table, in the listener set the menu data to be your table reference
and all you got to do is:
Table currTable = pare.getData();
Re: Adding menu to swt table [message #1066313 is a reply to message #1066244] Tue, 02 July 2013 02:53 Go to previous message
Hello li ran,
Thanks it is working now.
Previous Topic:Using processing with WindowBuilder
Next Topic:verifyKey not working as printed in the Eclipse article
Current Time: Fri Jul 25 20:04:09 EDT 2025
Powered by FUDForum. Page generated in 0.17577 seconds
