Home » Archived » Eclipse Examples » Issue with Login Popup(Issue with Login Popup)
Issue with Login Popup [message #1066126] Mon, 01 July 2013 03:10
Hello All,
Am trying to add a log-in dialog to my application. I have added this code in the
start method of the IApplication java file:
below is the code:
/* (non-Javadoc)
 * @see org.eclipse.equinox.app.IApplication#start
   org.eclipse.equinox.app.IApplicationContext)
	public Object start(IApplicationContext context) throws Exception {
		Display display = PlatformUI.createDisplay();
		if(aunthenticateUser(display)){
			try {
				int returnCode = PlatformUI.createAndRunWorkbench(display, new ApplicationWorkbenchAdvisor());
				if (returnCode == PlatformUI.RETURN_RESTART)
					return IApplication.EXIT_RESTART;
				else
					return IApplication.EXIT_OK;
			} finally {
				display.dispose();
		}else{
Now, the issue is: when the application starts the splash screen shows up first ( i have configured the splash screen in the productconfiguration file of the application). Then the login dialog appears.
Before entering the credentials in the login dialog, if the user closes the application by selecting the "close window" conext-menu from the windows task bar, the application closes (spash screen), but the login dialog doesn't close.
The login dialog is created as below in the IApplication.java
private boolean aunthenticateUser(Display display){
		boolean openApp = false;
		Shell shell = new Shell(display);
		final LoginDialog loginDia = new LoginDialog(shell);
		final int status = loginDia.open();
		if(status == Window.OK){
			openApp = true;
		loginDia.close();
		shell.dispose();
		shell = null;
		return openApp;
On debugging i noticed that, if the user closes the application before entering the credentials in the login dialog, the control doesn't come to the IApplicatio.java file itself. If this is the case, how can i close my Login dialog in this scenarion
Please let me know suggestion to resolve this issue
Previous Topic:Need examples for Eclipse 3.5's Editor, View, Formatter, more
Next Topic:tomcat issue
Current Time: Mon Jul 21 04:41:16 EDT 2025
Powered by FUDForum. Page generated in 0.06175 seconds
